Gravity: Ring 2D QR Code Scanner
$39.90
SKU: SEN0486
  • $38.80 3+ items
  • $38.00 5+ items
  • $36.80 10+ items
This highly integrated QR code scanner with excellent performance can recognize common 1D codes and 2D codes. With a small size, it employs easy-to-connect Gravity Interface and is equipped with a colorful indicator that feeds back the sensor recognition status by showing different colors.
Operating at 3.3V/5V, the scanner is compatible with UART and I2C communication, which makes it easier to develop on controllers like Arduino, ESP32, Raspberry Pi, etc.
Gravity:Ring 2D QR Code Scanner
Connection-Diagram with DFRduino UNO R3
It can be used in self-service vending machines, subway gates, access control, payment machines, etc.
  • Use-to-connect Gravity interface
  • 3.3V/5V power supply
  • I2C & UART supported
  • Self-service vending machines
  • Subway gates
  • Access control
  • Payment machines
  • Power Supply: DC3.3V/5V
  • Working Current: <70mA
  • Communication: I2C, UART
  • Image Pixel: 640*480
  • Light Source: colorful indicator/green light flashing prompt successful reading
  • Code System: 1D: EAN13, EAN8, UPCA, UPCE0, UPCE1, Code128, Code39, Code93, CodeBar, Interleaved 2 of 5
  •       2D: QR code, Data Matrix, PDF417
  • Depth of Field: QR Code (25mm-150mm product performance may be affected to varying degrees due to barcode quality and environmental conditions)
  • Contrast: ≥25%
  • Reading Angle: roll 360°, pitch 55°, yaw 55°
  • Scanning Angle: 69° (horizontal), 56° (vertical)
  • Reading Accuracy: ≥5mil
  • Working Temperature: 20°C ~60°C
  • Storage Temperature: -40°C ~80°C
  • Environment Light: 0~100000Lux
  • Relative Humidity: 5% to 95% (non-condensing)
  • Ring 2D QR Code Scanner x1
  • Adapter Board x1
  • PH2.0-4P Dupont Wire 30cm(Red Black Blue Green) x1
  • Gravity: Ring 2D QR Code Scanner
    $39.90
