5V COB LED Strip Light - White
$3.90
SKU: FIT0875
  • $3.80 3+ items
  • $3.70 5+ items
  • $3.50 10+ items
LED strip lights are always excellent decorations for various occasions. This kind of COB LED strip consists of 16 LEDs and its surface adopts LED silicone encapsulation for protecting the chips and maintaining a longer service life. It only needs DC 5V to work, which means there are more powering options. And they can be used in series or parallel.
With small size, uniform luminosity, high brightness and no shadows, you can use these LED strips to brighten every corner of your indoor rooms, wardrobes, stairs, wine cabinet, bookshelf, etc., or use in battery-operated lights projects.
Note: For long-term use, please paste the LED strip on the aluminum plate to prevent light decay or LED bead burnout since normally it gets hot during use.
5V COB LED Strip Light-White
LED Strip Dimension
LED Strip Light On
  • 5V power supply
  • High brightness, no shadows
  • Solderable, can be connected in series and parallel
  • Lighting Decoration
  • Working Voltage: DC 5V
  • Working Current: 600mA
  • Power: 3W
  • Brightness: 300LM
  • Luminous Color: white 6500k
  • LED Strip Size: 60*8*1.7mm /2.36*0.31*0.07 inch
  • Heat Sink Size: 70*20*3mm /2.76*0.79*0.12 inch
  • 5V COB LED Strip Light- White x1
  • Heat Sink x1
  • 5V COB LED Strip Light - White
