Gravity: LED Switch x 5 Pack
$17.00 $22.50
SKU: DFR0789
  • $22.00 3+ items
  • $21.50 5+ items
  • $21.00 10+ items
Purchase this product and earn 170 reward points, which are tied to VIP membership program. Learn More >
This is a simple LED-illuminated self-lock switch button. It’s just like a basic switch button, but it lights up color(red/yellow/green/blue/white) when pressed down, which gives you visual feedback. These little buttons can be used with micro:bit to realize various fun interactive projects, such as switch, backlight keyboard, music player panel, and recording control panel.
Gravity: LED Switch Kit
This is a self-lock switch button with LED light display.
Experimental Cases
Supports programming platforms like MakeCode, Mind+ and Arduino IDE.
1.Mind+ Program Example
Program Effect
Mind+ official download - Mind+ graphical programming software (mindplus.cc)For more fun, welcome to the Mind+ special column.
2.MakeCode Program Example
Program Effect
3.Arduino Program Example
Program Effect
  • 1. 5 lighting colors of red, green, white, yellow and blue are optional.
  • 2. Gravity interface, convenient and easy-to-use.
  • Gravity: LED Switch Kit
  • 3.Large buttons for easy control.
  • 4.With the self-locking function, the LED light does not go out when the button is released.
  • 5.Various types of stickers are provided.
  • Backlight keyboard
  • Music player panel
  • Recording control panel
  • Working Voltage: +3.3-5V (3.3V is recommended)
  • Output: Digital signal
  • Interface: PH2.0-3P
  • Size: 27 x 26.5mm
  • LED Light Color: red, yellow, green, blue, white
    Note: The module comes with a self-lock function. When the button is pressed down, the module outputs High, and the LED lights up. When being pressed again, the module outputs Low and the LED turns off.
  • Gravity: Digital Switch Button with LED x5 (red/ yellow / green/ blue/ white)
  • Digital Sensor Connector x5
  • Sticker x2
    Gun Away
    Projects Gun Away
    RoniBandini
    Feb 18, 2025
    Halloween trick or treat automata with Voice Recognition module
    Projects Halloween trick or treat automata with Voice Recognition module
    RoniBandini
    Oct 16, 2023
    Eye led push button for Arduino and Raspberry
    Projects Eye led push button for Arduino and Raspberry
    RoniBandini
    Nov 02, 2022
    Mr.'s Answering Machine
    Projects Mr.'s Answering Machine
    Frances
    Nov 01, 2021
    $53.00 $55.00
