This is a simple LED-illuminated self-lock switch button. It’s just like a basic switch button, but it lights up color(red/yellow/green/blue/white) when pressed down, which gives you visual feedback. These little buttons can be used with micro:bit to realize various fun interactive projects, such as switch, backlight keyboard, music player panel, and recording control panel.
This is a self-lock switch button with LED light display.
Experimental Cases
Supports programming platforms like MakeCode, Mind+ and Arduino IDE.
1.Mind+ Program Example
Program Effect
2.MakeCode Program Example
Program Effect
3.Arduino Program Example
Program Effect
Note: The module comes with a self-lock function. When the button is pressed down, the module outputs High, and the LED lights up. When being pressed again, the module outputs Low and the LED turns off.
