Gravity: Factory Calibrated Electrochemical CO Sensor (0-1000 ppm, I2C & UART)
$66.90
SKU: SEN0466
  • $65.00 3+ items
  • $64.00 5+ items
  • $62.00 10+ items
Purchase this product and earn 669 reward points, which are tied to VIP membership program. Learn More >
This is a sensor that detects carbon monoxide and supports three output modes: analog, I2C, and UART. The probe has been calibrated at the factory, which can quickly and accurately measure the concentration of carbon monoxide in the environment. Can be widely applied to fields like portable devices, air quality monitoring devices, industries, mines, warehouses, and other spaces where the air is not easy to circulate.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The sensor has 32 modifiable I2C addresses, an integrated temperature compensation algorithm, and a threshold alarm function, It has good compatibility with mainstream main control devices such as Arduino, ESP32, and Raspberry Pi. The easy-to-use Gravity interface, coupled with our sample code, can quickly build a carbon monoxide detector.
Gravity: CO Sensor (Calibrated)
  • High stability
  • High sensitivity
  • Petrochemical carbon monoxide detection
  • Metallurgy carbon monoxide detection
  • Mining carbon monoxide detection
  • Environmental protection
  • Detection Gas: Carbon Monoxide (CO)
  • Detection range: 0-1000ppm
  • Working Current: <5mA
  • Adapter Plate Size: 37*32mm
  • Gravity: CO Signal Conversion Board x1
  • CO sensor probe x1
  • Gravity - 4pin Cable x1
    How to Design and Construct Indoor Air Quality Monitoring System
    Blog How to Design and Construct Indoor Air Quality Monitoring System
    Jun 01, 2023
    Nemanja.Janev Mar 31, 2025
    Great product. good connectivity, easy setup
