Gravity: H2S Sensor (Calibrated) - I2C & UART
$72.90
SKU: SEN0467
  • $71.00 3+ items
  • $69.00 5+ items
  • $67.00 10+ items
Purchase this product and earn 729 reward points, which are tied to VIP membership program. Learn More >
This is a sensor that detects hydrogen sulfide concentration and supports three output modes: analog, I2C, and UART. The probe has been calibrated at the factory, which can quickly and accurately measure the concentration of hydrogen sulfide in the environment. Can be widely used in the detection of hydrogen sulfide in industrial, underground, and environmental protection fields.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The sensor has 32 modifiable I2C addresses, an integrated temperature compensation algorithm, and a threshold alarm function, It has good compatibility with mainstream main control devices such as Arduino, ESP32, and Raspberry Pi. The easy-to-use Gravity interface, coupled with our sample code, can quickly build a hydrogen sulfide concentration detector.
  • High stability
  • High sensitivity
  • Underground hydrogen sulfide detection
  • Industrial hydrogen sulfide detection
  • Detection Gas: Hydrogen sulfide (H2S)
  • Detection range: 0~100ppm
  • Working Current: <5mA
  • Adapter Plate Size: 37*32mm
  • Gravity: H2S Signal Conversion Board x1
  • H2S sensor probe x1
  • Gravity - 4pin Cable x1
  • FAQ
