Gravity: Factory Calibrated Electrochemical Nitrogen Dioxide Sensor (0-20ppm, I2C&UART)
$152.90
SKU: SEN0471
  • $148.00 3+ items
  • $145.00 5+ items
  • $140.00 10+ items
Purchase this product and earn 1529 reward points, which are tied to VIP membership program. Learn More >
This is a sensor that detects nitrogen dioxide concentration and supports three output modes: analog, I2C, and UART. The probe has been calibrated at the factory, which can quickly and accurately measure the concentration of Nitrogen Dioxide in the environment. Can be widely used in the detection of nitrogen dioxide in industrial, underground, and environmental protection fields.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The sensor has 32 modifiable I2C addresses, an integrated temperature compensation algorithm, and a threshold alarm function, It has good compatibility with mainstream main control devices such as Arduino, ESP32, and Raspberry Pi. The easy-to-use Gravity interface, coupled with our sample code, can quickly build a nitrogen dioxide concentration detector.
Gravity: NO2 Sensor (Calibrated) - I2C & UART
  • High stability
  • High sensitivity
  • Industrial nitrogen dioxide detection
  • Underground nitrogen dioxide detection
  • Detection Gas: Nitrogen Dioxide(NO2)
  • Detection range: 0~20ppm
  • Working Current: <5mA
  • Adapter Plate Size: 37*32mm
  • Gravity: NO2 Signal Conversion Board x1
  • NO2 sensor probe x1
  • Gravity - 4pin Cable x1
    AI-assisted Air Quality Monitor w/ IoT Surveillance
    Projects AI-assisted Air Quality Monitor w/ IoT Surveillance
    Kutluhan Aktar
    Apr 06, 2023
