Gravity: ENS160 Air Quality Sensor
$19.90
SKU: SEN0514
  • $19.40 3+ items
  • $19.00 5+ items
  • $18.40 10+ items
Indoor air quality sensor detects TVOC, eCO2, AQI using TrueVOC™ tech. Fast, stable, accurate data output after 3-minute warm-up. Ideal for pollution monitoring.
This Gravity: ENS160 Air Quality Sensor, based on ScioSense's new ENS160 sensor chip, is specifically designed for indoor air quality monitoring and offers detection of multiple IAQ data (TVOC, eCO2, AQI).
The innovative TrueVOC™ technology combines the metal oxide (MOX) technology that brings this sensor superior accuracy, fast response, anti-interference, etc. With intelligent on-chip algorithms, the ENS160 can directly output rich and easy-to-understand environmental data. Preheat the sensor 3 minutes before use then you can obtain accurate data more quickly. What's more, the built-in automatic baseline correction algorithm ensures the long-term stability of the sensor.
Board Overview
Connection Diagram
  • Multiple IAQ outputs (TVOC, eCO2, AQI), various environmental data
  • Less than 3 minutes warm-up time, get data faster
  • Built-in algorithm, more accurate output
  • Automatic baseline correction, more stable for long-term use
  • Air purification/home automation device
  • Environmental pollution detection
  • HVAC/Ventilation system
  • Building automation/smart thermostat
  • Electrical appliances/ range hoods
  • Power Supply Voltage: 3.3 V~5.5 V
  • Working Current: 29 mA
  • Interface Mode: I2C
  • I2C Address: 0x52, 0x53
  • Operating Temperature Range: -40℃~85℃
  • Working Humidity Range: 5 %RH~95 %RH
  • eCO2 Measurement Range: 400 ppm~65000ppm
  • TVOC Measuring Range: 0ppb~65000ppb
  • Product Size: 30x22 mm/1.18x0.87 inch
  • Gravity: ENS160 Air Quality Sensor x1
    2022 Top 10 New Products
    Blog 2022 Top 10 New Products
    Jan 10, 2023
    Danli
    Nov 08, 2024
    Danli
    Jan 25, 2024
    Steffen.Lorenz Apr 12, 2024
    Mega cool sensor to accurately measure air quality. With Python PinPong library, coding is super easy and quick. I think the same result should be possible with Adurino (did not test yet). Highly recommended!
    Ross.Cawston Jun 04, 2023
    Excellent sensor for VOC measurement; simple and easy to implement.
    Bryan.Humphrey May 18, 2023
    This is a great sensor for detecting VOCs and for indoor Air Quality monitoring. Using this sensor you can create a Air Quality index monitor along with thresholds to alert you when there is an increase in air pollutants. The sensor responds quickly to changes in the air quality and through I2c gives the raw data values as well as an air index value.
    $19.90
