Push-in Wire Connector (1 Input to 3 Outputs)
$2.50
SKU: FIT0893
  • $2.40 3+ items
  • $2.30 5+ items
  • $2.20 10+ items
The 1-in 3-out wire connector offers easy push-in connections, firm wiring, flame resistance, and anti-corrosion properties with CE certification.
This push-in 1-in 3-out wire connector can easily turn one input connection into 3 output connections. It features firm wiring, recyclability, flame retardant, and fire resistance. The conductive spring clamp inside the connector is made of nickel-coated steel, which is anti-corrosion, tight, not easy to loosen or fall off.
Dimension
  • Push-in connection, convenient to use
  • With CE certification
  • Power Supply Tool
    Electrical Parameters
  • Rated Voltage: 0-42V DC
  • Rated Current
  •             Input: 9A
                Output: 1.5A
  • Operating Temperature: 0-40°C
  • Connector Parameters
  • Input
                Solid/stranded conductor: 0.34-0.75mm²
                Tinned flexible conductor: 0.34-0.75mm²
                Flexible conductor with copper sleeve: 0.5-0.75 mm²
  • Output
                Solid/stranded conductor: 0.2-0.5mm²
                Tinned flexible conductor: 0.2-0.5mm²
                Flexible conductor with copper sleeve: 0.5mm²
  • Wiring Method: Push-in
  • Material Specifications
  • Insulation Material: Polyamide 66
  • Insulation Fire-proof level: UL 94V-2
  • Clamps: Copper and stainless steel
  • Size: 31*24*9.3mm (12.20*9.45*3.66 inch)
  • Push-in Wire Connector (1 Input to 3 Outputs) x1
