Fermion: STS35 High Accuracy Digital Temperature Sensor (Breakout)
$7.50
SKU: SEN0434
  • $7.30 3+ items
  • $7.20 5+ items
  • $6.90 10+ items
The STS35 temperature sensor from Sensirion gives a fully calibrated, linearized, and supply-voltage-compensated digital output and has an outstanding accuracy of up to +/–0.1°C.
It provides an operating temperature range of -40~125℃ and up to 1MHz I2C communication rate. Besides, the sensor can heat up itself to dehumidify the chip, which means it can function properly in a certain level of humidity.
Pinout
I2C Wiring Diagram
  • Factory calibrated, accurate digital output
  • High accuracy, ±0.1℃ temperature error
  • Fast startup time, 0.5ms
  • High reliability, long-term stability
  • Grain bin temperature monitoring
  • Precise temperature controlling in Lab
  • Ambient temperature detection in greenhouse
  • Temperature measuring in the environment with changeable humidity
  • Operating Voltage: 2.15~5.5V DC
  • Heating Power Consumption: 3.6~33mW
  • Output Signal: I2C
  • Measuring Range: -40~125℃
  • Accuracy: ±0.1℃
  • Resolution: 0.01℃
  • Preheat: ≤1.5ms (Typical, 0.5ms)
  • Response Time: >2s
  • Operating Temperature: -40~125℃
  • Size: 20x17.5x2mm/0.79x0.69x0.08”
  • Mounting Hole Size: M2(2mm); Pitch 15mm
  • Fermion: STS35 High Accuracy Digital Temperature Sensor x1
  • Only 1 Left
