9g 180° Micro Servo (1.6kg)
$3.50
SKU: SER0006
  • $3.45 2+ items
  • $3.40 5+ items
  • $3.30 10+ items
9g micro servo offers 1.6kg torque, ideal for small robots. Specs: 22.9x12.2x30mm, 4.8V-6V, 180° angle. Versatile for automation projects.
Purchase this product and earn 35 reward points, which are tied to VIP membership program. Learn More >
Do you need a servo for a tiny little project? Or are you seeking for an affordable solution? This mini servo is quite impressive, it does quite the job for a large range of tasks. Only weights 9 grams and gives you a 1.6kg cm torque. Pretty strong regarding its size. Suitable for Beam robots and other automation tasks. Keep in mind that if you need some heavy lifting you should be considering some of our other options. This servo is for you if you are planning on building smaller size robots.
  • Operating Voltage: 4.8V~6V
  • Operating Temperature: -10℃~50℃
  • No-load Speed: 130±10RPM/min(6V), 110±10RPM/min (4.8V)
  • No-load Current: ≤350mA (6V), ≤250mA (4.8V)
  • Stall Torque: ≥1.3kg*cm (6V), ≥1.0kg*cm (4.8V)
  • Stall Current: ≤1000mA (6V), ≤8000mA (4.8V)
  • Standby Current: ≤40mA (6V&4.8V)
  • Operating Angle: 180°±5°
  • Angle Difference on Both Sides: ≤5°
  • Centering Difference: ≤1°
  • Signal Range: 500usec~2500usec
  • Neutral Position: 1500usec
  • Wire Length: 250±5mm
  • Product Size: 22.9*12.2*30mm
  • Weight: 9±1g
  • 9g 180° micro servo (1.6kg)  x1
How to Make a Fully Rotational Servo
Blog How to Make a Fully Rotational Servo
Mar 17, 2016
The Last Servo Tester You Will Ever Need
Projects The Last Servo Tester You Will Ever Need
Mellow_labs
Apr 07, 2025
Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
Projects Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
RiverTrue
Nov 08, 2024
Top 10 micro:bit Machine Learning (AI) Projects You Must Try
Projects Top 10 micro:bit Machine Learning (AI) Projects You Must Try
RiverTrue
Jun 25, 2024
SCI Plant Monitor: The Smart Way to Track and Analyze Your Plant's Data for Growth
Projects SCI Plant Monitor: The Smart Way to Track and Analyze Your Plant's Data for Growth
Danli
Jun 25, 2024
Danli
Jan 10, 2024
