9g 180° Micro Servo (1.6kg)
$3.50
SKU: SER0006
  • $3.45 2+ items
  • $3.40 5+ items
  • $3.30 10+ items
Purchase this product and earn 35 reward points, which are tied to VIP membership program. Learn More >
Do you need a servo for a tiny little project? Or are you seeking for an affordable solution? This mini servo is quite impressive, it does quite the job for a large range of tasks. Only weights 9 grams and gives you a 1.6kg cm torque. Pretty strong regarding its size. Suitable for Beam robots and other automation tasks. Keep in mind that if you need some heavy lifting you should be considering some of our other options. This servo is for you if you are planning on building smaller size robots.
  • Operating Voltage: 4.8V~6V
  • Operating Temperature: -10℃~50℃
  • No-load Speed: 130±10RPM/min(6V), 110±10RPM/min (4.8V)
  • No-load Current: ≤350mA (6V), ≤250mA (4.8V)
  • Stall Torque: ≥1.3kg*cm (6V), ≥1.0kg*cm (4.8V)
  • Stall Current: ≤1000mA (6V), ≤8000mA (4.8V)
  • Standby Current: ≤40mA (6V&4.8V)
  • Operating Angle: 180°±5°
  • Angle Difference on Both Sides: ≤5°
  • Centering Difference: ≤1°
  • Signal Range: 500usec~2500usec
  • Neutral Position: 1500usec
  • Wire Length: 250±5mm
  • Product Size: 22.9*12.2*30mm
  • Weight: 9±1g
Projects
Project 1. Micro:bit Surprise box
In this project it shows how the box interacts with flahsing hearts.
Main Components:
micro:bit
DFRobot micro:bit Expansion Shield
DFRobot Ambient Light Sensor
Servo Motor 9g
Project 2: Free Energy? Charge Your Mobile Phone with Hands
Introduction: Wanna charge your phone in the apocalypse? Maybe my hand crank generator can help you.
Hardware components:
Project 3: How to make a Fingerprint ID Nerf Gun
My initial plans were to have the Arduino on the side with the power-pack and have the fingerprint ID scanner on the left side of the gun so that it can read the thumb print
Arduino Nano
Fingerprint Scanner
9g 180° Micro Servo
Project 4. How to make a Smart Rock-Paper-Scissors Game Robot
When finishing reading this tutorial, you will find those very simple devices, principles and technologies can help you build very interesting equipment.
Hardware list:
Project 5. FireBeetle Board-ESP32 Tutorials: Reforming a Small electric Fan
The instrument not just can record steps (and calories) at real time, but show time. What is special is that the format of showing is pointer.
Hardware in need:
Project 6 A Christmas present for cute kid & girl - A Clever Rabbit Hat - an EMG sensor based
Things you may need in this project:
  1. Gravity: Analog EMG Sensor by OYMotion   ×1
  2. Beetle - The Smallest Arduino       ×1
  3. Lithium Battery Charger         ×1
  4. 3.7 V Lithium Battery        ×1
  5. 9g 180° Micro Servo   ×2
  6. Rabbit Hat   ×1
  7. Needles and Thread
  8. Two-step Toggle Switch  ×1
  9. Elastic (Width: 1.5cm Length: 40cm) ×1
  10. Stick ×2
  11. Hot Melt Adhesive
Project 7: Micro:bit Missile Launcher
Project 8: micro:bit Laser Target
The ambient light sensor sensor detects the intensity of the laser pointer. If it is greater than 400, it will sound the buzzer and the servo will make the target fall and up. Game over when it reaches 10. Press A to reset score to 0.
  • 9g 180° micro servo (1.6kg)  x1
The Last Servo Tester You Will Ever Need
Projects The Last Servo Tester You Will Ever Need
Mellow_labs
Apr 07, 2025
Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
Projects Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
RiverTrue
Nov 08, 2024
Top 10 micro:bit Machine Learning (AI) Projects You Must Try
Projects Top 10 micro:bit Machine Learning (AI) Projects You Must Try
RiverTrue
Jun 25, 2024
SCI Plant Monitor: The Smart Way to Track and Analyze Your Plant's Data for Growth
Projects SCI Plant Monitor: The Smart Way to Track and Analyze Your Plant's Data for Growth
Danli
Jun 25, 2024
Danli
Jan 10, 2024
Unihiker chattering teeth optimistic news reader with ChatGPT
Projects Unihiker chattering teeth optimistic news reader with ChatGPT
RoniBandini
Sep 06, 2023
$27.00
