Note: One package has 10 cables.
This high-quality 30cm Gravity 4 Pin I2C/ UART sensor cable is equipped with 4 Pin PH2.0 plug connector on one side and DuPont male connector on the other side.
Compatible with breadboard and DuPont wire spacing, these cables use materials that are in line with RoHS requirements. Beautiful and delicate, it’s color labeled, which is convenient for distinguishing the polarity of sensor power supply and easy for wiring in building projects.
Jan 10, 2025
Use the cables to connect gravity sensors and actuators to the ESP32, RP2024 or RP2350. Even after being plugged in and unplugged several times, the plugs still don't come loose.
