ESP32-S3-WROOM-1-N4 Module (PCB Antenna)
$3.50
SKU: DFR0896
Purchase this product and earn 35 reward points, which are tied to VIP membership program. Learn More >
ESP32-S3-WROOM-1 is a powerful, generic Wi-Fi+ Bluetooth LE MCU module built around the ESP32-S3 series of SoCs. On top of a rich set of peripherals, the acceleration for neural network computing and signal processing workloads provided by the SoC makes the module an ideal choice for a wide variety of application scenarios related to Artificial Intelligence of Things (AIoT), such as wake word detection, speech commands recognition, face detection, and recognition, smart home, smart appliances, smart control panel, smart speaker, etc.
ESP32-S3 integrates multiple peripherals including SPI, LCD, Camera interface, UART, I2C, I2S, IR remote control, pulse counter, LED PWM, USB Serial/JTAG controller, MCPWM, SDIO host, GDMA, TWAI® controller (compatible with ISO 11898-1), ADC, touch sensor, temperature sensor, timers, and watchdogs, as well as up to 36 GPIOs. And it also includes a full-speed USB 1.1 On-The-Go (OTG) interface to enable USB communication.
Pinout
Pin Definitions
Name NO. Typea Function
GND 1 P GND
3V3 2 P Power supply
EN 3 I High level: on, enables the chip
Low level: off, the chip powers off
Note: Do not leave the EN pin floating
IO4 4 I/O/T RTC_GPIO4, GPIO4, TOUCH4, ADC1_CH3
IO5 5 I/O/T RTC_GPIO5, GPIO5, TOUCH5, ADC1_CH4
IO6 6 I/O/T RTC_GPIO6, GPIO6, TOUCH6, ADC1_CH5
IO7 7 I/O/T RTC_GPIO7, GPIO7, TOUCH7, ADC1_CH6
IO15 8 I/O/T RTC_GPIO15, GPIO15, U0RTS, ADC2_CH4, XTAL_32K_P
IO16 9 I/O/T RTC_GPIO16, GPIO16, U0CTS, ADC2_CH5, XTAL_32K_N
IO17 10 I/O/T RTC_GPIO17, GPIO17, U1TXD, ADC2_CH6
IO18 11 I/O/T RTC_GPIO18, GPIO18, U1RXD, ADC2_CH7, CLK_OUT3
IO8 12 I/O/T RTC_GPIO8, GPIO8, TOUCH8, ADC1_CH7, SUBSPICS1
IO19 13 I/O/T RTC_GPIO19, GPIO19, U1RTS, ADC2_CH8, CLK_OUT2, USB_D-
IO20 14 I/O/T RTC_GPIO20, GPIO20, U1CTS, ADC2_CH9, CLK_OUT1, USB_D+
IO3 15 I/O/T RTC_GPIO3, GPIO3, TOUCH3, ADC1_CH2
IO46 16 I/O/T GPIO46
IO9 17 I/O/T RTC_GPIO9, GPIO9, TOUCH9, ADC1_CH8, FSPIHD, SUBSPIHD
IO10 18 I/O/T RTC_GPIO10, GPIO10, TOUCH10, ADC1_CH9, FSPICS0, FSPIIO4, SUBSPICS0
IO11 19 I/O/T RTC_GPIO11, GPIO11, TOUCH11, ADC2_CH0, FSPID, FSPIIO5, SUBSPID
IO12 20 I/O/T RTC_GPIO12, GPIO12, TOUCH12, ADC2_CH1, FSPICLK, FSPIIO6, SUBSPICLK
IO13 21 I/O/T RTC_GPIO13, GPIO13, TOUCH13, ADC2_CH2, FSPIQ, FSPIIO7, SUBSPIQ
IO14 22 I/O/T RTC_GPIO14, GPIO14, TOUCH14, ADC2_CH3, FSPIWP, FSPIDQS, SUBSPIWP
IO21 23 I/O/T RTC_GPIO21, GPIO21
IO47 24 I/O/T SPICLK_P_DIFF, GPIO47, SUBSPICLK_P_DIFF
IO48 25 I/O/T SPICLK_N_DIFF, GPIO48, SUBSPICLK_N_DIFF
IO45 26 I/O/T GPIO45
IO0 27 I/O/T RTC_GPIO0, GPIO0
IO35b 28 I/O/T SPIIO6, GPIO35, FSPID, SUBSPID
IO36b 29 I/O/T SPIIO7, GPIO36, FSPICLK, SUBSPICLK
IO37b 30 I/O/T SPIDQS, GPIO37, FSPIQ, SUBSPIQ
IO38 31 I/O/T GPIO38, FSPIWP, SUBSPIWP
IO39 32 I/O/T MTCK, GPIO39, CLK_OUT3, SUBSPICS1
IO40 33 I/O/T MTDO, GPIO40, CLK_OUT2
IO41 34 I/O/T MTDI, GPIO41, CLK_OUT1
IO42 35 I/O/T MTMS, GPIO42
RXD0 36 I/O/T U0RXD, GPIO44, CLK_OUT2
TXD0 37 I/O/T U0TXD, GPIO43, CLK_OUT1
IO2 38 I/O/T RTC_GPIO2, GPIO2, TOUCH2, ADC1_CH1
IO1 39 I/O/T RTC_GPIO1, GPIO1, TOUCH1, ADC1_CH0
GND 40 P GND
EPAD 41 P GND
  • P: power supply; I: input; O: output; T: can be set to high impedance. Pin functions in bold font are the default ones. The default functions of pins 28 ~ 30 are determined by the eFuse bit.
  • In modules that have embedded OSPI PSRAM (i.e., that embed ESP32-S3R8), pins IO35, IO36, and IO37 are used to connect to the OSPI PSRAM and not available for other uses.
  • Features
  • Powerful and generic Wi-Fi and Bluetooth
  • Integrates multiple peripherals
  • Wake word detection
  • Speech commands recognition
  • Face detection and recognition
  • Smart home
  • Smart appliances
  • Smart control panel
  • Smart speaker
  • ESP32-S3 series of SoCs embedded, Xtensa® dual-core 32-bit LX7 microprocessor (support single-precision floating-point units), support the clock frequency of up to 240MHz
  • 384 KB ROM
  • 512 KB SRAM
  • 16 KB RTC SRAM
  • 4 MB SPI flash
  • Bluetooth LE: Bluetooth 5, Bluetooth mesh
  • 40MHz crystal oscillator
  • Module Dimension: 18x25.5x3.1(mm)/0.71x1.00x0.12(inches)
  • Operating Temperature: –40~85℃
  • ESP32-S3-WROOM-1-N4 Module (PCB Antenna) x1
    $3.50
