Solar Power Manager with Panel (9V)
$46.80
SKU: DFR0535-1
  • $45.40 3+ items
  • $44.50 5+ items
  • $43.00 10+ items
Purchase this product and earn 468 reward points, which are tied to VIP membership program. Learn More >
This kit includes Solar Power Manager (for 9V/12V/18V solar panel) and Solar Panel (9v 220mA).
The DFRobot Solar Power Manager series is designed for IoT projects and renewable energy projects, providing safe and high-efficiency embedded solar power management modules for makers and application engineers.
Solar Power Manager is complete small power and high-efficiency solar power management module. It features as MPPT (Maximum Power Point Tracking) function, maximizing the efficiency of the solar panel. Apart from serving as a solar charger, the module can provide up to 2A charging current to 3.7V Li battery with AC adapter (within 30V) or USB charger, three individual ON/OFF controllable DC-DC converters with 5V 1.5A, 3.3V 1A, and 9V/12V 0.5A outputs. These features satisfy the needs of various solar power projects and low-power applications. The module also employs various protect functions, such as Li-battery protection, battery/solar panel reverse connection protection, output over temperature, and over current/short circuit protection, which greatly improves the stability and safety of the system.
Check the brief specification for all Solar Power Manager Series Products.
Board Overview
DFR0535-Solar Power Manager Board Overview
Solar Power Manager
Connection Diagram
DFR0535-Build a solar powered system
Solar Power Manager (for 9V/12V/18V solar panel) Solar Power Manager 5V Solar Power Manager Micro (2V 160mA Solar Panel Included) Solar Power Manager For 12V Lead-Acid Battery
Name Solar Power Manager v1.0 Solar Power Manager 5v v1.1 Solar Power Manager Micro v1.0 Solar Power Manager v1.0
SKU DFR0535 DFR0559 DFR0579 DFR0580
Solar Power Management IC LTC3652 CN3065 SPV1050 CN3767
Solar Input Voltage 7V-30V 4.4V-6V 0.5V-4V 15V-25V
Maximum Charge Current 2A(Solar/USB) 900mA(Solar/USB) 70mA(Solar)/100mA(USB) 4A(Solar)
Topology DC-DC Buck Linear Regulator DC-DC Boost DC-DC Buck
Battery 3.7V Lithium Battery 3.7V Lithium Battery 3.7V Lithium Battery 12V Lead-Acid Battery
MPPT 9V/12V/18V Optional 5V Fixed 75% Open Voltage Fixed 18V
Battery Protections Over Charge/Over-Discharge/Over Current/Reverse Connection Protections Over Charge/Over-Discharge/Over Current/Reverse Connection Protections Over Charge/Over-Discharge/Reverse Connection Protections Over Charge/Over-Discharge/Reverse Connection Protections
Output Protections Short Circuit/Over Current/Over Heat Protections Short Circuit/Over Current Protections Short Circuit/Over Current Protections Short Circuit/Over Current/Over Heat Protections
USB Charge IN Yes Yes Yes No
USB OUT 5V 1.5A 5V 1A No 5V 2.5A x2
Regulated OUT Three Regulated Outputs 3.3V 1A;5V 1.5A;9V/12V 0.5A One Regulated Output 5V 1A One Regulated Output 3.3V 90mA Two Outputs 5V 5A; 12V 8A
Dimension 78.0mm×68.0mm 33.0mm×63.0mm 30.0mm×30.0mm 68.0mm×68.0mm
A complete multifunction solar power management module.
Applications: Small Solar Street Lamp, Solar Powered Robots
For 9V/12V/18V Solar Panels within20w
A small and easy-to-use 5V solar power management module.
Applications: Solar Power Bank, Solar Environment Monitors
For 5V Solar Panels within 10W
A micro power solar power management module for low-power sensors and controllers.
Applications: Wireless Sensor Network, BLE iBecon
For 1V/2V/3V Solar Panels within 0.5W
A medium power solar management module for 12V lead-acid batteries.
Applications: Street lighting, intelligent agriculture, environmental monitoring station, UPS
For 18V Solar Panels within 100W
  • Constant voltage MPPT algorithm, maximizing solar panel efficiency
  • 7V~30V wide solar panel input voltage
  • Various charging mode: solar/AC adapter/USB charger (2A max charge current)
  • Three individual ON/OFF controllable regulated power supply for low-power applications
  • All multi-layer ceramic capacitors (MLCC), safe, stable and high-efficiency
  • Various protection functions
  • USB connector with ESD shell
  • Smart solar environment monitor system
  • Solar-powered robot
  • Small solar street lamp
  • Solar power bank
  • Solar power management IC: LTC3652
  • Solar input voltage (SOLAR IN): 7V~30V
  • Battery input (BAT IN): 3.7V single-cell Li-polymer/Li-ion battery
  • Charge current(USB/SOLAR IN): 2A Max
  • Charging cutoff voltage(USB/SOLAR IN): 4.2V±1%
  • MPPT setting voltages: OFF/9V/12V/18V
  • USB IN voltage: 5V
  • Regulated power supply: OUT1=5V 1.5A; OUT2=3.3V 1A; OUT3=9V/12V 0.5A
  • Regulated power supply efficiency (3.7V battery IN)
     OUT1: 86%@50%Load
     OUT2: 92%@50%Load
     OUT3 (9V OUT): 89%@50%Load
  • USB charge efficiency: 84%@1A
  • Solar charge efficiency (18V SOLAR IN):78%@1A
  • Maximum quiescent current: <3 mA
  • Protections
     BAT IN: over charge /over-discharge /over current /reverse connection protection
     OUT1-OUT3/USB OUT: short circuit/over current/overheat protection
     SOLAR IN: reverse connection protection
  • Operation temperature:-40℃~85℃
  • Dimension:78.0mm*68.0mm
  • Solar Power Manager x1
  • Black Jumperbsp x3
  • M3 nylon pillar x4
  • M3 stainless steel screw x4
  • 14mm*14mm Aluminum cooling fin x1
  • 14mm*14mm Thermal conductive silicone pad x1
  • Female DC power jack adapter x1
  • Solar Panel (9v 220mA) x1
  • Solar Power Manager with Panel (9V)
    $46.80
