DC-DC Multi-output Buck Converter (3.3V/5V/9V/12V)
$5.30
SKU: DFR1015
  • $5.10 3+ items
  • $5.00 5+ items
  • $4.90 10+ items
This module converts 7.5V-30V input to 3.3V/5V/9V/12V output with protections, suitable for power control systems in LEDs, robots, drones, and more.
Purchase this product and earn 53 reward points, which are tied to VIP membership program. Learn More >
Multiple-output DC–DC converters are essential in a multitude of applications where different DC output voltages are required.
This DC-DC step-down voltage power module converts 7.5V~30V input to an output of 3.3V/5V/9V/12V (default to 5V), which can be selected by short-circuiting the corresponding pads on the back. It withstands up to 5A load current with suitable heat dissipation and has 70℃ over-temperature and overload protections. Besides, there is an onboard LED indicator that shows a solid red light when everything works fine and goes out when the protection mechanism is triggered and the voltage automatically drops to 0.1V.
The multi-voltage buck power module can be used in power control systems for LEDs, robots, drones, servos, low-power motors, and so on.
Instruction
This module outputs 5V by default and the corresponding 5V solder pad is short-circuited. To output other voltages, for instance, 3.3V, please disconnect the 5V pad and short-circuit the 3.3V solder pad.
Note: Since this is a step-down converter, the input voltage should be larger than the output, and it works better with a voltage difference of 2V and above.
Note: The output parameters are measured at 25 ℃, and the heat dissipation (heat sinks) is required for continuous large current load.
Dimension
  • Converts 7.5V~30V input to an output of 3.3V/5V/9V/12V
  • With suitable heat dissipation
  • With 70℃ over-temperature and overload protections
  • Power control systems
  • Input Voltage: 7.5V~30V (24V below is recommended)
  • Rated Output Parameters (Heat dissipation not required)
  •       3.3V/0~3A 5V/0~3A
          9V/0~2.5A 12V/0~3A
  • Maximum Output Parameters (Heat dissipation required)
  •       3.3V/5A (16.5W) 5V/5A (25W)
          9V/3.5A (31.5W) 12V/3.5A (42W)
  • Low Ripple: 30mV
  • Soldering Hole Pitch: 2.54mm (can solder pin headers)
  • Dimension: 2.7cm*2cm(length*width)/1.06*0.79"
  • DC-DC Multi-voltage Output Buck Power Module (3.3V/5V/9V/12V) x1
    Ionizing Radiation Detector
    Projects Ionizing Radiation Detector
    KGray
    Jun 25, 2024
    jérémi.darien May 10, 2025
    This is an amazing product
