DTOF STL-19P Laser LiDAR Sensor Kit (12m)
$119.00
SKU: SEN0547
  • $116.00 3+ items
  • $114.00 5+ items
  • $110.00 10+ items
Purchase this product and earn 1190 reward points, which are tied to VIP membership program. Learn More >
STL-19P LiDAR Sensor Kit
This STL-19P LiDAR sensor offers a ranging distance of up to 12m and 360° environmental scanning, which can realize autonomous mapping, and obstacle detection.
The sensor is compact and light, and its size nearly equals to a ping-pong ball and the weight nearly to 2 AA dry batteries.
DSTL-19P LiDAR Sensor Kit
Also, it can resist the strong light of 60 Klux, which achieves high-precision distance measurement indoors and outdoors.
The provided SDK works well with both ROS1 and ROS2 systems.
And the adopted brushless motor boasts long-lasting operation with high-speed data transmission.
Laser SafetyFDA Class I
Comparison of STL-19P and LD19 Technical Specification
  • Distance measurement up to 12m radius
  • Compact and stylish
  • Anti-Strong Light Interference
  • Long Lasting
  • Home Service Robot
  • Commercial Service Robot
  • Special robot
  • Drone
  • Industrial robot
  • STL-19P LiDAR Applications
  • Model: LD19
  • Ranging Distance: 0.02m~12m (target reflectivity of 70%)
  • Ranging Frequency: 4500Hz
  • Scanning Frequency: 10Hz(Typical)
  • Ranging Average Accuracy: ±45mm (0.3m~12m)
  • Ranging Standard Deviation: 10mm (0.3m~12m)
  • Measurement Resolution: 15mm
  • Scanning Range: 360°
  • Angle Error: ±2°
  • Angle Resolution: 0.8°@10Hz
  • Ambient Light Resistance: 30KLux
  • Laser Wavelength: 895~915nm(Typical 905nm)
  • Pitch Angle: 0-2°
  • Input Voltage: 5V
  • Operating Current: 180mA
  • Product Power: 0.9W
  • Dimensions: 38.59*38.89*33.50mm/1.52*1.53*1.32” (L*W*H)
  • Weight: 47g
  • Baud Rate: 230400
  • Communication Interface: UART (3.3V level)
  • Operating Temperature: -10℃~40℃
  • Storage Temperature: -30℃~70℃
  • Motor: Brushless Motor
  • STL-19P LiDAR Sensor ×1
  • Adapter Board ×1
  • 4PIN Cable ×1
  • USB Cable(Random Colors) ×1
  • DTOF STL-19P Laser LiDAR Sensor Kit (12m)
