Note: This titan case is only compatible with LattePanda 3 Delta 864.
Dedicated Design, Superior Texture
Titan case uses conflict aesthetics to combine functional design considerations with sci-fi elements. Understated color selection and layered surface treatment technology create a kind of design, flat but with unlimited potential.
Two Models, Balancing Extensibility And Integrity
Invisible quick-release cover design. A complete computer after fastening, or an open hardware development platform after quick disassembling.
Perfect Protection
High-strength engineering plastic effectively protects the internal precise electronic components from accidental falls and static damage in a complex development environment.
Note: Use M4 screws for the two middle holes in the bottom case, and make sure to control their length to avoid using screws that are too long, as they could damage the PCB when fully tightened. The maximum length for screwing from the outside of the shell to the inside is 7mm; screws that are 9mm long will touch the PCB. If you're mounting the case onto a device with a thickness of 'a' mm, the maximum screw length you should use is (a+7) mm.
Feb 16, 2025
Good case, very well designed. I was kind of scared it wouldn't be compatible with the touchscreen/display wires, but even that was thought of.
Dec 27, 2022
Nice sleek and futuristic-looking case. Arrived super-fast, fit the LattePanda 3 Delta I bought at the same time, and quick installation. I sometimes 3d-print cases, but it is really convenient to have one right from the manufacturer, so you know all the ports match openings correctly.
Oct 25, 2022
Great quality and smart design totally worth the price. You can attach easly wi-fi antennas in dedicated place and M2 Nvme SSD. The board is attached with screws to the bottom part and assembling the case is super easy.
