YDLIDAR GS2 - Linear Array Solid State LiDAR Sensor (25-300mm)
$38.00
SKU: DFR1030
High-precision LiDAR sensor with 100° FOV for obstacle avoidance and path planning in robots. Compact design, certified safety, detects small objects.
Purchase this product and earn 380 reward points, which are tied to VIP membership program. Learn More >
This is a Linear array solid LiDAR. Based on the principle of Triangulation, it is equipped with related optics, electricity, and algorithm design, to achieve 100 degrees of high-precision laser distance measurement, and output point cloud data of the scanning environment. It can be used for robot obstacle avoidance, path planning, etc.
Ultra-wide FOV to assist robot vacuum cleaner through blind spots
Field of View up to 100 degrees, Wide range of detection
Obstacle avoidance along the wall with performance improvement
The GS2 can obtain more measurement information in the vertical direction, helping smart devices such as robot vacuum cleaner and service robots with accurate real- time monitoring of the edge, efficiently complete multiple difficult tasks such as accurate.
Compact and light, flexible installation
The size of the whole device is only 25.6 (L) × 23.6 (H) × 10.8 (W) mm, which can be flexibly and easily integrated into various small smart devices. It can fully meet the refined detection needs of intelligent equipment such as robot vacuum cleaner.
Multiple authoritative certifications, high safety performance
Application scenario
Dimension
  • High precision, stable performance
  • Ranging angle up to 0.6°
  • Detectable smallest object diameter 3mm
  • Wide detection range, FOV up to 100°
  • Detection range of 25mm-300mm
  • Compliant with FDA Class I Security Standard
  • Service Life 10000h
  • Multiple authoritative certifications: CE, FCC, FDA, ROHS, Reach
  • Robot Works Alongside the Wall
  • Positioning Measurement
  • Anti-falling
  • Grab& Positioning of Robot
  • Detection-by Height
  • Supply voltage: 3.2-3.4V
  • Start-up current: 240mA
  • Working current: 100mA
  • Ranging distance: 25-300mm
  • Ranging frequency: 28Hz
  • Laser wavelength: 850nm
  • Field of view: 100°
  • Angle resolution: 0.6°
  • Relative error: Distance≤100mm (≤3mm)
                     100<Distance<200mm (≤3%)
                     200≤Distance<300mm (≤8%)
  • Angle error:±3°
  • Sunlight resistant: 25Klux
  • Operating temperature: -10~40°C
  • Storage temperature: -30~70°C
  • Life-time: 10000h
  • Size: 25.6*23.6*10.8mm
  • Linear Array Solid LiDAR x1
  • Adapter Board x1
  • 4Pin Connector Wire x1
  • USB to Type-C Cable x1
    Lidar Types and How They Work
    Blog Lidar Types and How They Work
    Mar 30, 2023
    7 Real-World Applications of LiDAR Technology
    Blog 7 Real-World Applications of LiDAR Technology
    Apr 12, 2023
    Exploring the Differences: Solid-State LiDAR vs Mechanical LiDAR
    Blog Exploring the Differences: Solid-State LiDAR vs Mechanical LiDAR
    Sep 13, 2023
    Ayaz.Ahmed May 17, 2025
    its good and accurate.
    Muhammad Adli.Rizqulloh Jul 15, 2024
    It can work as well and delivered as fast as expected
