Gravity: GR10-30 Gesture Sensor (UART & I2C, 12 Gestures, 0~30cm)
$23.00
SKU: SEN0561
  • $22.50 3+ items
  • $22.00 5+ items
  • $21.00 10+ items
This gesture sensor recognizes 12 hand movements, supports UART/I2C communication, and operates non-contact applications up to 30cm range.
Purchase this product and earn 190 reward points, which are tied to VIP membership program. Learn More >
This GR10-30 gesture sensor is capable of recognizing 12 hand gestures: move up, down, left, right, forward, backward, rotate clockwise and counterclockwise, rotate clockwise and counterclockwise continuously, hover, and wave. And users can set parameters such as the gesture trigger distance, the hand rotation angle, the hovering time that can be recognized, and the size of the recognition window to get more accurate results.
The GR10-30 features stable performance and high accuracy within a sensing distance of up to 30 cm. Meanwhile, it provides two interrupt pins for indicating if a gesture trigger occurs and if an object enters the recognition range.
The sensor is well suited to non-contact operation applications like gesture remote controllers, robot interaction, human-machine interface control, lighting control, and gesture game machine.
Wiring Diagram of Arduino Uno and Gravity: GR10-30 Gesture Sensor
Figure: Wiring Diagram of Arduino and Gravity: GR10-30 Gesture Sensor
  • Maximum recognition distance of 30cm
  • Capable of recognizing 12 gestures
  • Configurable recognition threshold & other parameters
  • Support UART & I2C communication
  • Gesture Remote Controller
  • Robot Interaction
  • Human-machine Interface Control
  • Supply Voltage: 3.3V to 5V
  • Operating Current: <10mA
  • I2C Address: 0x73
  • Serial Baud Rate: 9600
  • Maximum Recognition Distance: 30cm
  • Operating Temperature:0℃ to 70℃
  • Operating Humidity:5%RH to 85%RH
  • Dimension:22×30mm/0.87×1.18"
  • Gravity: GR10-30 Gesture Sensor × 1
  • Gravity-4P I2C/UART Sensor Cable × 1
    UNIHIKER: GR10-30 gesture sensor
    Projects UNIHIKER: GR10-30 gesture sensor
    Lupin
    Aug 05, 2024
    Steffen.Lorenz Jan 21, 2024
    The sensor does exactly what is promised and recognizes my hand gestures very accurately. I realized my successes after just a few minutes on the Raspberry Zero with Python. I also created an I2C driver for MicroPython on ESP32, here is the link: https://github.com/Lupin3000/Micropython-I2C-GR10_30 ... DFRobot really offers very good quality and I think that this is not the last sensor that I will order here and use for my DIY projects.
    Julian.van Hemert Feb 16, 2025
    I haven't tried it yet. But the product came in perfect condition and, like all products well-packaged.
