The ROCK 5B is a robust, high-performance, and versatile ARM SBC (Single Board Computer) founded on the formidable Rockchip RK3588 SoC, replete with top-tier features, outstanding functionality, and extensive expansion options as standard.
Incorporating a Quad Arm Cortex A76 CPU, Quad Arm DynamIQ Cortex A55, Arm Mali G610MC4 GPU, stereo audio jack, dual HDMI ports capable of supporting displays up to 8Kp60 resolution, micro-HDMI input port capable of supporting up to 4Kp60 resolution, and a multitude of connectivity and storage options, it is compatible with an extensive range of software operating systems as standard. Prepare to elevate your designs with the ROCK 5B.
The onboard On/Off power button enables the ROCK 5B to perform safe shutdowns with a single touch, eliminating the risk of storage corruption. It also boasts multiple storage capabilities and comes equipped with an eMMC socket as standard. The board's exceptional features, remarkable performance, and dependability make it the ideal choice for even the most demanding multimedia and industrial applications.
Reliable Rockchip SoC
The ROCK 5B delivers reliable and robust performance, founded on the Rockchip RK3588 SoC, Arm DynamIQ Quad Cortex-A76 @ 2.2/2.4GHz, Quad Cortex-A55 @ 1.8GHz CPU, Arm Mali-G610MC4 GPU, and 8GB 64bit LPDDR4 RAM. You can rest assured that your board will provide exceptional performance - it’s as solid as a ROCK!
Super handy power on/off button for safe shutdowns
Tired of having to input code into the command line to safely shut down your single-board computer? The ROCK 5B features a built-in On/Off power button, allowing you to perform safe shutdowns with a single touch, without the risk of storage corruption. This immense convenience comes as standard with the ROCK 5B, providing you with flexibility in your applications.
More OS, more options
The ROCK 5B is highly versatile, boasting compatibility with a multitude of operating systems, including Android 12, Debian/Ubuntu Linux, the full implementation of the Arm architecture v8 instruction set, and more.
No storage limitations
The ROCK 5B boasts extensive storage capacity, 8GB RAM, and a high-speed eMMC socket for eMMC modules that can be utilized for both OS and data storage.
Highly compatible with SBC accessories
The 40-pin GPIO expansion header supports a vast array of interface options, endowing the board with virtually limitless connectivity capabilities and ensuring exceptional compatibility with a plethora of SBC accessories.
Figure: Pinout of ROCK 5B
Unrivaled 8K display
The ROCK 5B single-board computer that supports 8K display. With an Arm Mali G610MC4 graphics processing unit (GPU) at its core, the ROCK 5B is custom-built for advanced multimedia applications, including gaming, video playback, and digital signage. The board boasts camera and display interfaces, two HDMI ports capable of supporting dual displays up to 8Kp60 and 4Kp60 resolution, a micro-HDMI input port capable of supporting up to 4Kp60 resolution, high-quality stereo audio output via a 3.5mm audio jack, and much more.
Figure: Supports 8K Display
True thermal management
The ROCK 5B features a PWM fan connector (with power output and voltage to be confirmed) and two heatsink mounting holes, ensuring that no matter how demanding your application may be, the ROCK 5B will deliver exceptional performance under most conditions. We think that's pretty cool!
Figure: Dimensional Drawing of Rock 5B
