FireBeetle 2 Board ESP32-S3 (N16R8) AIoT Microcontroller with Camera (16MB Fl., 8MB PS., Wi-Fi & BT on Board)
$19.90
SKU: DFR0975
  • $19.40 3+ items
  • $19.00 5+ items
  • $18.40 10+ items
FireBeetle 2 ESP32-S3 is a high-performance main controller built around the ESP32-S3-WROOM-1-N16R8 module. In addition, this microcontroller is equipped with an OV2640 camera, enabling it to excel in applications such as image recognition. The ESP32-S3 module also boasts ample storage capacity and a rich set of communication interfaces, catering to a wide range of application requirements. With its enhanced capabilities, the FireBeetle 2 ESP32-S3 opens up endless possibilities for various projects and functionalities.
Image Recognition
FireBeetle 2 ESP32-S3 offers an onboard camera interface for easy connection with a camera. Also, an independent camera power supply circuit is designed, which helps reduce interference from other signals to the camera. The board comes with an OV2640 camera that offers 2 megapixels, a 68°FOV, and up to 1600*1200 resolution.
For instance, in a smart home scenario, the board's camera can be utilized to monitor the situation at home. When someone enters, it can automatically send notifications and store the captured image data for reporting purposes.
FireBeetle 2 Board ESP32-S3 Image recognition
Image recognition
FireBeetle 2 Board ESP32-S3 Video picture transmission
Powerful Chip and More Storage Space
The acceleration for neural network computing and signal processing workloads provided by the ESP32-S3 chip makes the module an ideal choice for a wide variety of applications, such as speech recognition, image recognition, and so on.
For instance, when training for facial recognition, it is possible to store a greater number of facial models. This allows for faster results when conducting data comparisons.
ESP32-S3 Powerful Chip
Powerful Chip
Dual-Mode Communication
In addition, FireBeetle 2 ESP32-S3 supports WiFi and Bluetooth 5 (LE) dual-mode communication, which reduces the difficulty of networking. Meanwhile, both Bluetooth Mesh protocol and Espressif WiFi Mesh are supported for more stable communication and a larger coverage area. With the support of Matter protocol, the microcontroller can be used to develop industrial standard smart home devices for a wider range of IoT and AIoT (Artificial Intelligence of Things) scenarios.
User-Friendly
This development board is designed to be user-friendly, addressing the complexity of screen wiring through its onboard GDI screen interface. Additionally, it integrates power management features, supporting battery charging and hardware power control. The FireBeetle 2 ESP32-S3 can be programmed using the Arduino IDE, ESP-IDF, and MicroPython, allowing developers to utilize both C and Python to interact with the hardware.
Comparison Table
FireBeetle 2 Board ESP32-S3 (N16R8) AIoT Microcontroller FireBeetle 2 Board ESP32-S3-U (N16R8) AIoT Microcontroller
WiFi Soldered on the board Routed through a cable
Bluetooth Soldered on the board Routed through a cable
Cohesive design,
more visually appealing
Better signal quality
  • Image Recognition:Onboard GDI for easy connection with screens
  • Powerful Chips: ESP32-S3 module with AI Acceleration
  • More storage space: 16MB Flash & 8MB PSRAM
  • Onboard camera interface & independent camera power supply, easy to connect and strong anti-interference
  • Power management integrated, support Li-ion battery charging and hardware On/OFF controlling
  • Wi-Fi and Bluetooth 5 dual-mode communication
  • AIoT-related projects
  • Speech recognition
  • Image recognition
    Basic Parameters
  • Operating Voltage: 3.3V
  • Type-C Input Voltage: 5V DC
  • VCC Input Voltage: 5V DC
  • Max Charging Current: 1A
  • Operating Temperature: -20 to 70℃
  • Dimension: 25.4x60mm/1x2.36”
    Hardware Information
  • Processor: Xtensa® dual-core 32-bit LX7 microprocessor
  • Main Frequency: 240 MHz
  • SRAM: 512KB
  • ROM: 384KB
  • Flash: 16MB
  • PSRAM: 8MB
  • RTC SRAM: 16KB
  • USB: USB 2.0 OTG full-speed
    WIFI
  • WIFI Protocol: IEEE 802.11b/g/n
  • Bandwidth: Support 20 MHz and 40 MHz at 2.4 GHz band
  • WIFI Mode: Station, SoftAP, SoftAP+Station combined mode
  • WIFI Frequency: 2.4GHz
  • Frame Aggregation: TX/RX A-MPDU, TX/RX A-MSDU
    Bluetooth
  • Bluetooth Protocol: Bluetooth 5, Bluetooth mesh
  • Bluetooth Frequency: 125 Kbps, 500 Kbps, 1 Mbps, 2 Mbps
    Ports
  • Digital I/O x26
  • LED PWM Controller 8 Channels
  • SPI x2
  • UART x3
  • I2C x2
  • I2S x2
  • IR Transceiver: transmit channel x5, receive channel x5
  • 2×12-bit SAR ADC, 20 Channels
  • DMA Controller: transmit channel x5, receive channel x5
  • FireBeetle 2 Board ESP32-S3 (N16R8) AIoT Microcontroller (Supports Wi-Fi & Bluetooth) x1
  • OV2640 Camera x1
  • 18pin-2.54mm Pin Header x1
  • 18pin-2.54mm Female Header x1
  • 14pin-2.54mm Pin Header x1
  • 14pin-2.54mm Female Header x1
    ESP32 Edge AI Camera
    Projects ESP32 Edge AI Camera
    Mukesh Sankhla
    Feb 18, 2025
    Multi-Model AI-Based Mechanical Anomaly Detector w/ BLE
    Projects Multi-Model AI-Based Mechanical Anomaly Detector w/ BLE
    Kutluhan Aktar
    Feb 09, 2024
    Evan.Khee Jul 26, 2023
    Equipped with the ESP32 espressif chip, it is one of the best in the market currently. I was happy to see that both headers were given for my choice.
