Flexible LED Filament (24V 1200mm, 2200K)
$11.90
SKU: FIT0927
  • $11.60 3+ items
  • $11.40 5+ items
  • $11.00 10+ items
This flexible filament is 1200mm long, with a diameter of only 2mm and 640 LEDs. It can be used for DIY lighting decoration and 360° all-angle lighting fixtures. It comes with adjustable brightness and requires a 21-24V power supply. The positive electrode is at the small round hole end and the negative electrode is at the non-porous end. It can be bent and folded as desired, providing 360-degree light without dead angles.
Note: To avoid excessive heat that can damage the filament, a power supply of 21-22V is recommended for long-term use.
Dimension of Flexible LED Filament
Figure: Dimension
24V 1200mm LED Flexible Filament (2700K) 24V 1200mm LED Flexible Filament (2200K)
24V 1200mm Green LED Flexible Filament 24V 1200mm Red LED Flexible Filament
24V 1200mm Blue LED Flexible Filament 12V 600mm LED Flexible Filament (2200K)
Figure: Flexible LED Filament Lighting Effects
Clicking the image will take you to the corresponding product page.
  • 1200mm in length, high brightness, suitable for DIY
  • 21-24V power supply, adjustable brightness
  • Compact size, positive and negative poles identified
  • Flexible filament, can be bent and folded as desired
  • Long lifespan of 5000-10000 hours
  • E-Textiles (smart fabrics): Incorporate electronic functionality.
  • LED filament light bulbs: Resemble traditional incandescent light bulbs with visible filaments for aesthetic and light distribution purposes but with the high efficiency of light-emitting diodes (LEDs).
  • Length: 1200mm
  • Emitting Color: 2200K(Warm white)
  • Color Rendering Index: 80
  • Luminous Flux: 500lm
  • Supply Voltage: 21-24V
  • Working Current: 300mA @ 22V
  • Power: 6.6W @ 22V
  • Operating Temperature: -30 to +55°C
  • Storage Temperature: -10 to +40°C
  • Storage Humidity: 60%RH
  • Lifespan: 5000-10000 hours
  • 24V 1200mm LED Flexible Filament (2200K) x1
  • Flexible LED Filament (24V 1200mm, 2200K)
