Flexible LED Filament (24V 1200mm, Red)
$13.90
SKU: FIT0929
  • $13.60 3+ items
  • $13.30 5+ items
  • $12.90 10+ items
Measuring 1200mm in length with a 2mm diameter, this flexible filament has 640 LEDs that can be used for DIY lighting decoration and 360° all-angle lighting fixtures. It comes with adjustable brightness and requires a 21-24V power supply, with the positive electrode at the small round hole end and the negative electrode at the non-porous end. Its flexible design allows it to be bent and folded according to your needs, providing 360-degree light coverage.
Note: A power supply of 21-22V is recommended for prolonged use to avoid damage due to excessive heat.
Dimension of Flexible LED Filament
Figure: Dimension
24V 1200mm LED Flexible Filament (2700K) 24V 1200mm LED Flexible Filament (2200K)
24V 1200mm Green LED Flexible Filament 24V 1200mm Red LED Flexible Filament
24V 1200mm Blue LED Flexible Filament 12V 600mm LED Flexible Filament (2200K)
Figure: Flexible LED Filament Lighting Effects
Clicking the image will take you to the corresponding product page.
  • 1200mm in length, high brightness, suitable for DIY
  • 21-24V power supply, adjustable brightness
  • Compact size, positive and negative poles identified
  • Flexible filament, can be bent and folded as desired
  • Long lifespan of 5000-10000 hours
  • E-Textiles (smart fabrics): Incorporate electronic functionality.
  • LED filament light bulbs: Resemble traditional incandescent light bulbs with visible filaments for aesthetic and light distribution purposes but with the high efficiency of light-emitting diodes (LEDs) .
  • Length: 1200mm
  • Emitting Color: Red
  • Color Rendering Index: 80
  • Luminous Flux: 500lm
  • Supply Voltage: 21-24V
  • Working Current: 300mA @ 22V
  • Power: 6.6W @ 22V
  • Operating Temperature: -30 to +55°C
  • Storage Temperature: -10 to +40°C
  • Storage Humidity: 60%RH
  • Lifespan: 5000-10000 hours
  • 24V 1200mm LED Flexible Filament (Red) x1
  • Review
    Wayco.Luis Aug 24, 2024
    Absolutely, the product arrived in a timely fashion. It made a beautiful lamp and works well. I used it with a 3.6-5 volt power source and high frequency voltage transformer with dimmer control. The luminescence of all the LEDs in the strand is beautiful and it works great. I am looking forward to buying from you again. Unfortunately, the first package got stolen by a neighbor. However, your company was kind enough to attempt to replace it in a timely fashion. Thank you for upholding your company's honor and ensuring delivery. I will use DHL shipping from now on as it is quite impressive. I definitely like the product and it was worth the money paid. Your company's courtesy gets an A+++ as well as your assurance of delivery, even out of spite of what happened. Thank you again.
