Fermion: MEMS Carbon Monoxide CO Gas Detection Sensor (Breakout, 5-5000ppm)
$4.90
SKU: SEN0564
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.60 10+ items
The sensor detects CO using MEMS technology, offering compact size, low power consumption, and quick response. Ideal for CO alarms, not for quantitative use.
Fermion: MEMS Carbon Monoxide CO Gas Detection Sensor employs state-of-the-art micro electromechanical system (MEMS) technology, endowing the sensor with compact dimensions (13x13x2.5mm), low power consumption (<20 mA), minimal heat generation, a short preheating time, and swift response recovery. The sensor can measure carbon monoxide gas concentrations qualitatively and is suitable for carbon monoxide leak alarms and portable carbon monoxide detectors.
Please note: This sensor is capable of only qualitative measurements. For quantitative measurements, kindly consider purchasing the Gravity: Factory Calibrated Electrochemical CO Sensor (0-1000 ppm, I2C & UART).
Wiring Diagram of Fermion: MEMS CO sensor and Arduino UNO
Figure: Wiring Diagram of Fermion: MEMS CO sensor and Arduino UNO
Precautions for use
  • Features
  • Low power consumption
  • Advanced MEMS technology
  • Petrochemical carbon monoxide detection
  • Metallurgy carbon monoxide detection
  • Mining carbon monoxide detection
  • Environmental protection
  • Gas detected: CO
  • Detection range: 5-5000ppm
  • Operating voltage: 3.3-5V
  • Operating current: <20 mA
  • Sensitivity: R0(in air)/Rs(in 150ppm CO) ≥ 3
  • Lifespan: ≥5 years (in air)
  • Dimension:13×13 x 2.5mm/0.0.51×0.51x0.1"
  • Fermion: MEMS Carbon Monoxide CO Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
    Jul 27, 2023
    Smart Solar Plant(Environment monitoring)
    Projects Smart Solar Plant(Environment monitoring)
    RAJESHKT
    May 17, 2024
    Only 11 Left
    $58.00
