Fermion: MEMS Smoke Detection Sensor - 10-1000ppm Range (Ethanol Compatible, Breakout)
$4.90
SKU: SEN0570
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.60 10+ items
This ultra-compact MEMS sensor provides reliable qualitative smoke detection (10-1000ppm) with rapid response time - ideal for IoT safety systems and industrial monitoring applications.
Space-Saving 13mm Design
At just 13×13×2.5mm, this sensor fits into tight spaces where conventional detectors can't - perfect for embedded systems and compact IoT devices.
Ultra-Low Power Operation
Consumes <20mA current (3.3-5V) - 60% less power than traditional smoke detectors, enabling battery-powered monitoring solutions.
Fast Response Recovery
Advanced MEMS technology delivers detection within seconds - 3x faster response than conventional smoke sensors for critical early warnings.
Multi-Gas Compatibility
Pairs with 10 other MEMS sensors (CO, VOC, H2, etc.) to create comprehensive air quality monitoring systems with shared power/interface.
Please note: This sensor is capable of only qualitative measurements. For quantitative measurements, kindly consider purchasing the Gravity: Factory Calibrated Electrochemical Gas Sensor Series.
Precautions for use
  • IoT smoke alarm systems
  • Industrial equipment overheating detection
  • Kitchen safety monitoring
  • Laboratory safety equipment
  • Smart home ventilation control
  • Detection Range: 10-1000ppm (qualitative)
  • Target Gases: Ethanol, smoke particulates
  • Output: Analog voltage (0-5V)
  • Sensitivity: R0/Rs ≥3 @200ppm EtOH
  • Power: 3.3-5V DC, <20mA
  • Response Time: <15 seconds
  • Operating Temp: -10°C to 50°C
  • Humidity Range: 15-90% RH
  • Lifespan: 5+ years continuous use
  • Dimensions: 13×13×2.5mm
  • Fermion: MEMS Smoke Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
    Jul 27, 2023
    No-Code Gas Detector Prototype
    Projects No-Code Gas Detector Prototype
    RosarIoT
    Aug 09, 2024
    Smoke and methane detection with FireBeetle 2 ESP32-C6 and Alvik robot
    Projects Smoke and methane detection with FireBeetle 2 ESP32-C6 and Alvik robot
    RoniBandini
    Aug 05, 2024
