Fermion: Formaldehyde Sensor (Breakout, 0-3ppm MEMS HCHO Detection, Low Power)
$4.90
SKU: SEN0563
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.60 10+ items
Ensure safe indoor air quality with the Fermion MEMS Formaldehyde Sensor (HCHO), a high-sensitivity detector for 0-3ppm gas concentrations. Perfect for HVAC systems, air purifiers, and portable monitors, this low-power sensor delivers fast, reliable results with MEMS technology.
High Sensitivity & Fast Response
The MEMS-based sensor detects HCHO concentrations (0-3ppm) with rapid recovery times, ensuring real-time monitoring for health-critical environments.
Ultra-Low Power Consumption (<20mA)
Designed for battery-operated devices, the sensor’s minimal power draw extends operational life in portable detectors and IoT deployments.
Compact & Easy to Integrate
At just 13×13×2.5mm, the sensor fits seamlessly into air purifiers, smart wearables, and Arduino/Raspberry Pi projects with analog voltage output.
Durable for Long-Term Use
With a 3-year lifespan and -10°C to 50°C operating range, it withstands diverse environments while avoiding interference from humidity or contaminants.
Precautions for use
  • Features
  • Low power consumption,operating current <20mA
  • Advanced MEMS technology
  • Air purifiers
  • HVAC systems
  • Smart wearables
  • Portable detectors
  • Gas detected: Formaldehyde (HCHO)
  • Detection range: 0-3ppm
  • Operating voltage: 3.3-5V
  • Operating current: <20mA
  • Sensitivity: R0(in air)/Rs(in 0.4ppm HCHO) ≥ 1.8
  • Lifespan: ≥3 years (in air)
  • Dimension:13×13 x 2.5mm/ 0.0.51×0.51x0.1"
  • Fermion: MEMS Formaldehyde HCHO Gas Detection Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
    Jul 27, 2023
