Fermion: H2S Gas Sensor – Hydrogen Sulfide Detector (Breakout, 0.5-50ppm, MEMS, Low Power)
$7.50
SKU: SEN0568
  • $7.20 3+ items
  • $7.10 5+ items
  • $6.90 10+ items
Protect against toxic hydrogen sulfide (H2S) exposure with the Fermion MEMS H2S Sensor, a high-sensitivity detector for 0.5-50ppm gas concentrations. Designed for sewers, waste treatment, and industrial safety, this low-power sensor delivers fast, accurate results with MEMS technology.
Accurate H2S Detection (0.5-50ppm)
The MEMS-based hydrogen sulfide sensor detects low to high concentrations with high sensitivity, ensuring reliable safety monitoring in hazardous environments.
Ultra-Low Power (<20mA) & Compact
At just 13×13×2.5mm, this energy-efficient sensor integrates seamlessly into portable detectors and IoT safety systems.
Fast Response & Long Lifespan (≥5 Years)
With minimal preheating time and durable construction, the sensor is ideal for continuous monitoring in high-humidity or corrosive environments.
Please note: This sensor is capable of qualitative measurements only. For quantitative measurements, kindly consider purchasing the Gravity: Factory Calibrated Electrochemical Gas Sensor Series.
Precautions for use
  • Features
  • Low power consumption, operating current <20mA
  • Advanced MEMS technology
  • Hydrogen sulfide detection in toilets, sewers, garbage stations
  • Gas detected: Hydrogen Sulfide (H2S), Benzene
  • Detection range: 0.5-50ppm
  • Operating voltage: 3.3-5V
  • Operating current: <20mA
  • Sensitivity: R0 (in air)/Rs (in 50ppm H2S) ≥ 3
  • Lifespan: ≥5 years (in air)
  • Dimension: 13×13 x 2.5mm/0.0.51×0.51x0.1”
  • Fermion: MEMS H2S Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
  • Fermion: H2S Gas Sensor – Hydrogen Sulfide Detector (Breakout, 0.5-50ppm, MEMS, Low Power)
