Fermion: NH3 Gas Sensor – Ammonia Detector (Breakout, 1-300ppm, MEMS, Low Power)
$7.50
SKU: SEN0567
  • $7.20 3+ items
  • $7.10 5+ items
  • $6.90 10+ items
Prevent toxic ammonia (NH3) exposure with the Fermion MEMS NH3 Sensor, a high-sensitivity detector for 1-300ppm gas concentrations. Designed for cold storage, aquaculture, and industrial safety, this low-power sensor delivers fast, accurate results with MEMS technology.
Accurate NH3 Detection (1-300ppm)
The MEMS-based ammonia sensor detects low to high concentrations with high sensitivity, ensuring reliable safety monitoring in hazardous environments.
Ultra-Low Power (<20mA) & Compact
At just 13×13×2.5mm, this energy-efficient sensor integrates seamlessly into portable detectors and IoT safety systems.
Fast Response & Long Lifespan (≥5 Years)
With minimal preheating time and durable construction, the sensor is ideal for continuous monitoring in high-humidity or corrosive environments.
Please note: This sensor is capable of qualitative measurements only. For quantitative measurements, kindly consider purchasing the Gravity: NH3 Sensor (Calibrated).
Precautions for use
  • Ammonia leakage in cold storage
  • Aquaculture risk control
  • Toilet odor monitoring
  • Gas detected: Ammonia (NH3)
  • Detection range: 1-300ppm
  • Operating voltage: 3.3-5V
  • Operating current: <20mA
  • Sensitivity: R0(in air)/Rs(in 50ppm NH3) ≥ 3
  • Lifespan: ≥5 years (in air)
  • Dimension:13×13 x 2.5mm/0.0.51×0.51x0.1"
  • Fermion: MEMS NH3 Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
  • Fermion: NH3 Gas Sensor – Ammonia Detector (Breakout, 1-300ppm, MEMS, Low Power)
