Fermion: NH3 Gas Sensor – Ammonia Detector (Breakout, 1-300ppm, MEMS, Low Power)
$7.50
SKU: SEN0567
  • $7.20 3+ items
  • $7.10 5+ items
  • $6.90 10+ items
Compact MEMS ammonia sensor with low power consumption, fast response, and qualitative measurement for applications like cold storage and odor monitoring.
Prevent toxic ammonia (NH3) exposure with the Fermion MEMS NH3 Sensor, a high-sensitivity detector for 1-300ppm gas concentrations. Designed for cold storage, aquaculture, and industrial safety, this low-power sensor delivers fast, accurate results with MEMS technology.
Accurate NH3 Detection (1-300ppm)
The MEMS-based ammonia sensor detects low to high concentrations with high sensitivity, ensuring reliable safety monitoring in hazardous environments.
Ultra-Low Power (<20mA) & Compact
At just 13×13×2.5mm, this energy-efficient sensor integrates seamlessly into portable detectors and IoT safety systems.
Fast Response & Long Lifespan (≥5 Years)
With minimal preheating time and durable construction, the sensor is ideal for continuous monitoring in high-humidity or corrosive environments.
Please note: This sensor is capable of qualitative measurements only. For quantitative measurements, kindly consider purchasing the Gravity: NH3 Sensor (Calibrated).
Precautions for use
  • Ammonia leakage in cold storage
  • Aquaculture risk control
  • Toilet odor monitoring
  • Gas detected: Ammonia (NH3)
  • Detection range: 1-300ppm
  • Operating voltage: 3.3-5V
  • Operating current: <20mA
  • Sensitivity: R0(in air)/Rs(in 50ppm NH3) ≥ 3
  • Lifespan: ≥5 years (in air)
  • Dimension:13×13 x 2.5mm/0.0.51×0.51x0.1"
  • Fermion: MEMS NH3 Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
    Jul 27, 2023
