Fermion: VOC Gas Sensor – Volatile Organic Compounds Detector (Breakout, 1-500ppm, MEMS)
$4.90
SKU: SEN0566
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.60 10+ items
Compact VOC sensor using MEMS technology; measures indoor air quality. Features low power use, small size, rapid response. Qualitative detection only.
Improve indoor air quality and safety with the Fermion MEMS VOC Sensor, a high-sensitivity detector for volatile organic compounds (1-500ppm). Designed for homes, offices, and industrial environments, this low-power sensor delivers fast, accurate results with MEMS technology.
Wide VOC Detection (1-500ppm)
The MEMS-based sensor detects formaldehyde, toluene, ethanol, and other harmful VOCs, ensuring reliable air quality monitoring.
Ultra-Low Power (<20mA) & Compact
At just 13×13×2.5mm, this energy-efficient sensor integrates seamlessly into air purifiers, IoT devices, and portable detectors.
Fast Response & Long Lifespan (≥5 Years)
With minimal preheating time and durable construction, the sensor is ideal for continuous monitoring in high-humidity or polluted environments.
Please note: This sensor is capable of only qualitative measurements. For quantitative measurements, kindly consider purchasing the Gravity: Factory Calibrated Electrochemical Gas Sensor Series.
Precautions for use
  • Features
  • Low power consumption, operating current <20mA
  • Advanced MEMS technology
  • Environmental monitoring: identify the sources and levels of benzene in the ambient air
  • Indoor air quality: measure the concentration of formaldehyde in the indoor air
  • Industrial safety: detect any leaks or spills of tetrachloroethylene
  • Fire detection: detect the early signs of fire and smoke by sensing the changes in the composition and concentration of VOCs in the air.
  • Health applications: measure the amount of acetone in the breath and provide feedback or guidance for diabetes management.
  • Gas detected: ethanol, formaldehyde, toluene, etc
  • Detection range: 1-500ppm
  • Operating voltage: 3.3-5V
  • Operating current: <20mA
  • Sensitivity: R0 (in air)/Rs (in 50ppm ethanol) ≥ 3
  • Lifespan: ≥5 years (in air)
  • Dimension:13×13 x 2.5mm/0.0.51×0.51x0.1"
  • Fermion: MEMS VOC Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
    Jul 27, 2023
    No-Code Gas Detector Prototype
    Projects No-Code Gas Detector Prototype
    RosarIoT
    Aug 09, 2024
