Fermion: MEMS Ethanol Gas Sensor - Compact EtOH Detector (1-500ppm, Breakout)
$4.90
SKU: SEN0569
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.60 10+ items
The MEMS Ethanol sensor offers compact size, low power consumption, and rapid response for qualitative ethanol detection, suitable for gas leakage and portable detectors.
This advanced MEMS ethanol sensor provides reliable qualitative detection of alcohol vapors (1-500ppm), perfect for breathalyzer development and industrial safety applications.
Ultra-Compact Design
At just 13×13×2.5mm, this micro sensor fits seamlessly into portable devices and wearables while consuming <20mA power - ideal for battery-powered applications.
Fast Response Technology
MEMS construction enables rapid detection with minimal preheating time, delivering immediate vapor concentration alerts when alcohol is present.
Multi-Purpose Detection
Sensitive to both ethanol (EtOH) and volatile organic compounds (VOCs), making it versatile for breath analysis, food quality monitoring, and industrial safety systems.
Simple Integration
Standard 3.3-5V operation with analog output connects effortlessly to Arduino and other microcontrollers via the included breakout board.
Long Operational Life
Robust MEMS technology ensures ≥5 years of continuous service in normal conditions when properly maintained.
Please note: This sensor is capable of only qualitative measurements. For quantitative measurements, kindly consider purchasing the Gravity: Factory Calibrated Electrochemical Gas Sensor Series.
Wiring Diagram of Fermion: MEMS EtOH Sensor and Arduino UNO
Figure: Wiring Diagram of Fermion: MEMS EtOH Sensor and Arduino UNO
Precautions for use
  • Features
  • Low power consumption, operating current <20mA
  • Advanced MEMS technology
  • Portable breathalyzer devices
  • Food/beverage quality control
  • Industrial alcohol vapor monitoring
  • Laboratory safety systems
  • Smart home VOC detection
  • Detection Range: 1-500ppm EtOH
  • Output: Analog voltage (0-5V)
  • Sensitivity: R0/Rs ≥3 (in 50ppm EtOH)
  • Power: 3.3-5V DC,<20mA
  • Response Time: <30 seconds
  • Operating Temp: -10°C to 50°C
  • Dimensions: 13×13×2.5mm
  • Lifespan: 5+ years
  • Fermion: MEMS Ethanol EtOH Gas Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
    Jul 27, 2023
