Fermion: MEMS Odor Smell Gas Detection Sensor (Breakout, 0.5-50ppm)
$4.90
SKU: SEN0571
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.60 10+ items
Fermion: MEMS Odor Smell Gas Detection Sensor employs state-of-the-art microelectromechanical system (MEMS) technology, endowing the sensor with compact dimensions (13x13x2.5mm), low power consumption (<20mA), minimal heat generation, short preheating time, and swift response recovery. The sensor can qualitatively measure odor gas concentration, suitable for breath detector, odor detection and other application scenarios.
Please note: This sensor is capable of only qualitative measurements. For quantitative measurements, kindly consider purchasing the Gravity: Factory Calibrated Electrochemical Gas Sensor Series.
Wiring Diagram of Fermion: MEMS Odor Sensor and Arduino UNO
Figure: Wiring Diagram of Fermion: MEMS Odor Sensor and Arduino UNO
Precautions for use
  • Features
  • Low power consumption, operating current <20mA
  • Advanced MEMS technology
  • Aviation safety: monitors the presence of hazardous gases or vapors in the aircraft cabin or cockpit.
  • Spoiled food material detection: evaluates the freshness and safety of food products by detecting the emission of odor compounds.
  • Body odor detection: analyzes the human body odor and provides feedback or suggestions for personal hygiene or health care.
  • Other health applications: diagnoses or monitors various health conditions by detecting the changes in breath or skin odor.
  • Gas detected: H2S, EtOH, acetone, etc
  • Detection range: 0.5-50ppm
  • Operating voltage: 3.3-5V
  • Operating current: <20mA
  • Sensitivity: R0(in air)/Rs(in 5ppm H2S) ≥ 2
  • Lifespan: ≥5 years (in air)
  • Dimension:13×13 x 2.5mm/0.0.51×0.51x0.1"
  • Fermion: MEMS Odor Smell Gas Detection Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
  • FAQ
    $12.90
