Fermion: MEMS Hydrogen H2 Gas Detection Sensor (Breakout, 0.1-1000ppm)
$13.90
SKU: SEN0572
  • $13.50 3+ items
  • $13.30 5+ items
  • $12.90 10+ items
Fermion: MEMS H2 sensor employs state-of-the-art micro-electromechanical system (MEMS) technology, endowing the sensor with compact dimensions (13x13x2.5mm), low power consumption (<20mA), minimal heat generation, short preheating time, and swift response recovery. The sensor can measure the concentration of hydrogen gas qualitatively. It is suitable for the hydrogen leakage alarm and other application scenarios.
Please note: This sensor is capable of only qualitative measurements. For quantitative measurements, kindly consider purchasing the Gravity: Factory Calibrated Electrochemical Gas Sensor Series.
Wiring Diagram of Fermion: MEMS H2 Sensor and Arduino UNO
Figure: Wiring Diagram of Fermion: MEMS H2 Sensor and Arduino UNO
Precautions for use
  • Features
  • Low power consumption, operating current <20mA
  • Advanced MEMS technology
  • Air quality monitoring: measures the level of H2 and other pollutants in the ambient air.
  • Automotive emission control: monitors the H2 emission from fuel cell vehicles and adjusts the fuel cell operation to optimize the performance and efficiency.
  • Industrial safety: detects the leakage or exposure of H2 and other flammable gases in industrial processes or workplaces.
  • Gas detected: Hydrogen (H2)
  • Detection range: 0.1-1000ppm
  • Operating voltage: 3.3-5V
  • Operating current: <20mA
  • Sensitivity: R0(in air)/Rs(in 200ppm H2) ≥ 5
  • Lifespan: ≥5 years (in air)
  • Dimension:13×13 x 2.5mm/0.0.51×0.51x0.1"
  • Fermion: MEMS H2 Sensor (breakout) × 1
  • 2.54mm pitch header pin × 1
  • Fermion: MEMS Hydrogen H2 Gas Detection Sensor (Breakout, 0.1-1000ppm)
    $45.90
