15.6 Inch 1920x1080 IPS Type-C Touch Screen & Display for Raspberry Pi / LattePanda / Jetson Nano Single Board Computer
$229.00
SKU: DFR1045
15.6" touch display with 1920x1080 resolution, IPS technology, Type-C/HDMI interfaces, and wide compatibility with various computing devices. Supports 10-point touch.
Purchase this product and earn 1900 reward points, which are tied to VIP membership program. Learn More >
Featuring a 15.6-inch capacitive touch display, this product stands out with its high resolution of 1920x1080, full-function Type-C and HDMI dual display interfaces, IPS hard screen technology, optical bonding, and support for ten-point capacitive touch. It exhibits extensive compatibility, capable of connecting with single-board computers such as the LattePanda series, Raspberry Pi 4B, Jetson Nano, as well as various desktop computers, laptop computers, mini PCs, industrial computers, and tablet computers. It is suitable for use in human-machine interaction scenarios, such as terminal device control panels, IoT control panels, and more.
Superior Performance Parameters
This 15.6-inch large screen display boasts a high resolution of 1920x1080, ensuring clear visual effects. It adopts IPS hard screen technology and an optical bonding process, further enhancing the display effect. The surface is treated with anti-glare, enhancing the user experience. In addition, it also supports ten-point capacitive touch.
15.6-inch 1920x1080 ten-point capacitive touch display
Multi-functional Type-C Interface
Equipped with two full-featured Type-C interfaces, supporting blind plugging, eliminating the need for users to specifically distinguish between data ports and power ports. These interfaces can achieve audio transmission, video transmission, and touch function through a Type-C data cable, while also supporting reverse PD power supply, providing power for the connected devices.
Full-featured Type-C interfaces
Multiple Interface Design
In addition to the multi-functional Type-C interface, this display also retains the traditional HDMI interface to ensure compatibility with more HDMI output devices.
Supports both Type-C and HDMI video transmission methods
Wide Compatibility
The display is suitable for various single-board computers, including but not limited to LattePanda Sigma, LattePanda 2 Alpha, LattePanda 2 Delta, LattePanda 3 Delta, Raspberry Pi 4B, and Jetson Nano. In addition, it is also compatible with various desktop computers, laptop computers, mini PCs, industrial computers, and tablet computers.
Compatible with Raspberry Pi 4B, LattePanda, LattePanda Alpha/Delta, and LattePanda Delta 3 installations.
Easy to Integrate
The display supports the installation of the LattePanda series and Raspberry Pi 4B development boards, providing more convenient choices for project integration.
Easy to Integrate
Certified Quality and Safety Compliance
After being tested and verified by accredited institutions, the display screen complies with the CE-EMC electromagnetic compatibility requirements and CE-LVD electrical safety requirements, ensuring stable performance, safe quality, and compliance.
If you need the report, please click here.
  • Supports ten-point capacitive touch
  • Supports dual-channel audio output
  • Supports both Type-C and HDMI video transmission methods
  • The full-featured Type-C interface allows single-line connection for video, audio, and touch signals, and supports reverse PD power delivery.
  • Type-C does not require distinguishing between power and data interfaces, supporting blind insertion.
  • Compatible with Raspberry Pi 4B, LattePanda, LattePanda Alpha/Delta, and LattePanda Delta 3 installations.
  • Compatible with various desktop computers, laptops, mini PCs, industrial computers, and tablets.
  • Human-Machine Interaction Panel
  • Terminal Control Panel
  • IoT Control Panel
    Screen parameters
  • LCD size: 15.6 inches
  • Resolution: 1920×1080
  • Pixel pitch (um): 179.25(H) × 179.25(V)
  • Pixel arrangement : RGB Vertical Stripe
  • Color gamut: 45%
  • Display colors: 262k (6-bit)
  • Active area(mm): 344.16(H)×193.59(V)
  • Surface treatment: Anti-Glare
  • Surface hardness: 3H
  • Brightness: 250cd/㎡
  • Refresh rate: 60Hz
  • Transmittance: ≥86%
  • View angle: Full-view angle
  • Number of touch: 10
  • Touch panel hardness: ≥6H
  • Bonding method: Optical bonding
  • Outline dimension(mm): 369.5(H)×288.6(V)×5.2(D)
  • Interface: eDP
  • LCD brand: BOE
  • Operating temperature: 0~+50℃
  • Weight: 766g
  • Display driver board parameters
  • Display interface: Type-C/HDMI
  • Speaker interface: MX1.25-4P
  • Touch interface: Type-C
  • Power interface: Type-C
  • Power voltage: PD3.0, 5~20V
  • Mounting hole size: Hole diameter 3.0mm
  • PCB size(mm): 125(V)×110(H)×1.6(D)
  • Touch control board parameters
  • Touch chip: ILI2511
  • Touch interface: MX1.25-4P
  • PCB size(mm): 50(H)×26(V)×4.8(D)
  • 15.6" 1920×1080 IPS Type-C Capacitive Touch Screen ×1
  • Display Driver Board ×1
  • Touch Control Board ×1
  • eDP Screen Connection Cable 210mm ×1
  • Dual-Head MX1.25-4P Touch Screen Cable ×1
  • HDMI A to A Adapter Module for LattePanda Delta 3 ×1
  • HDMI A to A Adapter Module for LattePanda Delta/Alpha ×1
  • HDMI A to D Adapter Module for Raspberry Pi ×1
  • M3×6+8mm Single-Head Copper Pillar × 5
  • M3×6+9mm Single-Head Copper Pillar × 5
  • M2.5×6+8mm Single-Head Copper Pillar ×5
  • M3×6 Round Head Screw × 5
  • M2.5×6 Round Head Screw ×5
  • Product Certificate and Warranty Card ×1
  • 15.6 Inch 1920x1080 IPS Type-C Touch Screen & Display for Raspberry Pi / LattePanda / Jetson Nano Single Board Computer
