Featuring a 64-bit quad-core Arm Cortex-A76 processor running at 2.4GHz, Raspberry Pi 5 delivers a 2–3× increase in CPU performance relative to Raspberry Pi 4.
Alongside a substantial uplift in graphics performance from an 800MHz VideoCore VII GPU, it supports dual 4Kp60 display output over HDMI and provides state-of-the-art camera support through a rearchitected Raspberry Pi Image Signal Processor. This combination ensures a smooth desktop experience for consumers and opens the door to new applications for industrial customers.
For the first time, this is a full-size Raspberry Pi computer using silicon built in-house
at Raspberry Pi. The RP1 “southbridge” provides the bulk of the I/O capabilities for
Raspberry Pi 5, and delivers a step change in peripheral performance and functionality.
Aggregate USB bandwidth is more than doubled, yielding faster transfer speeds to external UAS drives and other high-speed peripherals; the dedicated two-lane 1Gbps MIPI camera and display interfaces present on earlier models have been replaced by a pair of four-lane 1.5Gbps MIPI transceivers, tripling total bandwidth, and supporting any combination of up to two cameras or displays; peak SD card performance is doubled, through support for the SDR104 high-speed mode; and for the first time the platform exposes a single-lane PCI Express 2.0 interface, providing support for high-bandwidth peripherals.
Dimension Diagram of Raspberry Pi 5 Single Board Computer
Interface Diagram of Raspberry Pi 5 single-board computer
Raspberry Pi Fifth Flagship Development Computer: Feature a 64-bit quad-core Arm Cortex-A76 processor running at 2.4GHz, using silicon built in-house at Raspberry Pi, offering a step change in peripheral performance and functionality
Significant Graphics Capability: Equip an 800MHz VideoCore VII GPU and deliver better graphics performance, suitable for multimedia applications, gaming, and graphics-intensive tasks
State-of-the-Art Camera Support: Built with the dedicated dual 4-lane 1Gbps MIPI DSI/CSI connectors, tripling total bandwidth, and supporting any combination of up to two cameras or displays
Versatile Connectivities: Offer Gigabit Ethernet and a PCIe interface, along with dual-band Wi-Fi and Bluetooth 5.0/BLE wireless capability
Enhanced Peripherals: Provide 1x UART connector, 1x microSD card slot supporting high-speed, 2x USB.0 3.0 supporting sync 5Gbps operation, 2x USB2.0 ports ports, 1x RTC, 2x 4Kp60 display output with HDR support
PC alternatives
Multimedia Center
Console
Education and Learning Tools
Smart Home Systems
Sensor Network
Remote Monitoring
Industrial Automation
Embedded Systems Development
CPU: 2.4GHz quad-core 64-bit Arm Cortex-A76 CPU, with cryptography extensions, 512KB per-core L2 caches, and a 2MB shared L3 cache
GPU: VideoCore VII GPU, supporting OpenGL ES 3.1, Vulkan 1.2
Display Output: Dual 4Kp60 HDMI® display output with HDR support
Video Decoder: 4Kp60 HEVC decoder
RAM: 8GB LPDDR4X-4267 SDRAM
Wi-Fi: Dual-band 802.11ac Wi-Fi®
Bluetooth: Bluetooth 5.0/ Bluetooth Low Energy (BLE)
Storage: microSD card slot, with support for high-speed SDR104 mode
Power Button: On/Off included
USB Ports:
2 × USB 3.0 ports, supporting simultaneous 5Gbps operation
2 × USB 2.0 ports
Ethernet: Gigabit Ethernet, with PoE+ support (requires separate PoE+ HAT)
Camera/Display: 2 × 4-lane MIPI camera/display transceivers
PCIe Interface: PCIe 2.0 x1 interface for fast peripherals (requires separate M.2 HAT or other adapter)
Power: 5V/5A DC power via USB-C, with Power Delivery support
Raspberry Pi Header: Raspberry Pi standard 40-pin header
Real-time Clock (RTC): Powered from external battery
Raspberry Pi 5 Single Board Computer - 8GB x1 Resource
Blog Deploy and run LLM on Raspberry Pi 5 vs Raspberry Pi 4B (LLaMA, LLaMA2, Phi-2, Mixtral-MOE, etc)
Blog Run Small Language Models (Mathstral, phi 3, Llama 3.1, Gemma2 2b, Qwen) on Raspberry Pi 5
Blog Raspberry Pi 5: Next-Level CPU Performance and Enhanced Interfaces Revealed!
Blog How to Select SBC (Lattepanda/Raspberry Pi) for Local LLM (LLaMA, LLaMA2, Phi-2, Mixtral-MOE, etc.)
Blog New Raspberry Pi Compute Module 5 Review and Guide for Embedded Systems
Blog Run phi3.5 on Raspberry Pi 5 using Ollama
Mitchell.Scholz May 14, 2025
Zaw Min.Htwe Jan 09, 2025
Rifqi.Abdillah Jan 02, 2025
