SATA Power Cable for LattePanda Sigma (PH2.0 4 Pin to SATA 15 Pin, 40cm)
$1.50
SKU: FIT0951
This 40cm power cable connects SATA devices to a single-board computer. It features a SATA-15P female connector, PH2.0-4P terminal, and pure copper conductors.
Purchase this product and earn 15 reward points, which are tied to VIP membership program. Learn More >
This is a power supply cable specifically designed for connecting SATA devices to the LattePanda Sigma Single Board Computer.
It features a SATA-15P female connector and a PH2.0-4P terminal, with a cable length of 40cm.
This cable can be used to supply power to SATA interface hard drives or other devices connected to the LattePanda Sigma single-board-computer.
Diagram of Interface Cable Colors
Interface Diagram
  • LattePanda Sigma Board Power Supply
  • Interface: PH2.0-4P, SATA-15P female connector
  • Length: 40cm
  • Cable Colors: PH2.0 end - Yellow (12V), Black (GND), Black (GND), Red (5V); SATA end - Yellow, Black, Red, Black
  • Wire Gauge: 20AWG
  • Insulation Material: PVC insulation
  • Conductor Material: Pure copper
  • Cable Outer Diameter: OD1.8mm
  • SATA to PH2.0 Connection Line for LattePanda Sigma (40cm) x1
  • Review
    Michael.Barton Apr 01, 2025
    Have not used it yet, but it should work just fine. Will need to wait untill I have an ssd for install.
    Out Of Stock
