7'' 1024x600 Touch Display (eDP) for LattePanda Mu / LattePanda Sigma
$79.90
SKU: FIT0950
  • $77.00 3+ items
  • $76.00 5+ items
  • $74.00 10+ items
Purchase this product and earn 799 reward points, which are tied to VIP membership program. Learn More >
The 7" Touch Display (eDP) combines excellent visual quality with practical features designed for human-machine interface (HMI) and portable projects. This display adopts cutting-edge IPS screen technology, ensuring full visual angle support, a high resolution of 1024 x 600, and vibrant color saturation.
Excellent Visual Effect
This display adopts IPS screen technology, supports FULL visual Angle, 1024 x 600 high resolution, and high color saturation, achieve excellent picture.
Designed For HMI and Portable Projects
We have made many product design optimizations for HMI and portable project requirements. For example, HMI scenarios are often complex and dusty, but this display uses a fully fit design to perfectly prevent dust from entering the screen, and also effectively reduces the reflection of light. In order to make the screen easy to be installed, the screen edge comes with the special double-sided adhesive tape, which can be easily and firmly fixed.
7 inches 1024x600  Touch Display (eDP) for LattePanda Sigma
Best Compatibility
Unlike other normal HDMI screens, this display uses eDP interface and has the best compatibility with LattePanda Mu / LattePanda Sigma.
Wiring Diagram of Display and LattePanda Mu
Wiring Diagram of Display and LattePanda Sigma
Please refer to the instruction sticker at the back of the screen for proper screen connection.
How to Install the 7'' eDP Touch Display for LattePanda Sigma: A Step-by-Step Assembly Guide
Please note: Designed exclusively for the LattePanda Sigma single board computers.
  • Wide viewing angle for enhanced visibility from different perspectives
  • Multi-touch functionality for intuitive interaction
  • High-quality display with vivid and accurate color reproduction
  • Compact and lightweight design for easy integration into various projects
  • Durable construction with a 6H surface hardness for scratch resistance
  • Quick response time for smooth and responsive touch operations
  • Compatible with the LattePanda Sigma model for seamless integration
  • Versatile applications in human-machine interface (HMI) and portable projects
  • LattePanda Sigma Single Board Computer
  • Compatible Models: LattePanda Mu / LattePanda Sigma
  • Resolution: 1024 x 600 high resolution
  • Interface: eDP(DP)+I2C(TP)
  • Transmittance:85%
  • Surface Hardness: 6H
  • Response Time: ≤16ms
  • LCM Luminance: 250 cd/m2
  • Tapping Durability: 200,000,000 times
  • Connector: 30cm FPC Extension Cable
  • Pixel pitch (W×H) 0.1506 × 0.1432 mm
  • Active area (W×H) 154.21 × 85.92 mm
  • Dimensions: 180*110*5 mm / 7.1*4.3*0.2 inches
  • Operating Temperature -20 ~ +70 ℃
  • Storage temperature -30 ~ +80 ℃
  • Weight(Screen Only): 157.7g
  • 7 inches eDP Touch Display x1
  • 30cm eDP cable x1
  • 23cm Touch cable with Same-Side Contacts x2 (For LattePanda Sigma)
  • 21cm Touch cable with Opposite-Side Contacts x1 (For LattePanda Mu)
  • 7'' 1024x600 Touch Display (eDP) for LattePanda Mu / LattePanda Sigma
    $79.90
