This is an Aluminum case and heat sink kit built specifically for the Raspberry Pi CM4 IoT Router Carrier Board Mini. The kit allows the Raspberry Pi CM4 IoT Router Carrier Board Mini to be safely housed within a power distribution box, eliminating concerns about short circuits on the exposed PCB.
The cooling solution kit features an integrated all-metal casing and heat sink, engineered to efficiently dissipate heat from the BCM2711. This ensures optimal performance by preventing overheating, even when operating at full capacity.
Installation Steps of CM4 IoT Router Mini and Case
(Not Include Compute Module 4 IoT Router Carrier Board Mini)
