Beetle ESP32 C6 Mini Development Board for Wireless Smart Wearable Device (Supports BLE / Matter)
$4.90
SKU: DFR1117
  • $4.80 3+ items
  • $4.70 5+ items
  • $4.60 10+ items
Beetle ESP32-C6 is a mini size Arduino low-power IoT development board based on the ESP32-C6 chip, featuring a compact design with dimensions as small as a coin (25*20.5mm). The ESP32-C6 is equipped with a high-performance 160MHz RISC-V 32-bit processor, supporting communication protocols such as Wi-Fi 6, Bluetooth 5, Zigbee 3.0, Thread 1.3, and Matter. It is capable of connecting to various IoT networks using multiple communication protocols, making it ideal for use as a Matter terminal device. The development board integrates lithium battery charging management, allowing for battery charging without the need for external modules. This feature contributes to a more compact project size, making it highly suitable for wearable applications.
Highly integrated with an ultra-compact size
In a form factor no larger than a coin, the Beetle ESP32-C6 provides up to 13 IO ports, alleviating concerns about insufficient IO ports during project development. The Beetle ESP32-C6 integrates lithium battery charging management, ensuring the safe charging of lithium batteries. Moreover, this development board supports battery voltage monitoring, enabling proactive measures to be taken in case of low battery levels, guaranteeing continuous device operation.
Comparison of the size between the Beetle ESP32-C6 and the keycap
Figure: Comparison of the size between the Beetle ESP32-C6 and the keycap
Multiple transmission protocol support to expand wireless connectivity
Boasting support for multiple communication protocols, the Beetle ESP32-C6 expands wireless connectivity options. By supporting Wi-Fi and Thread protocols, it enables the creation of Matter Wi-Fi terminal devices and Matter Thread terminal devices, facilitating seamless communication and collaboration among multiple systems and platforms in smart home setups. Additionally, the Beetle ESP32-C6 supports BLE (Bluetooth Low Energy), Zigbee communication protocols, and now also includes support for Matter, making it suitable for use as a Thread border router, Matter gateway, or Zigbee bridge when combined with other MCUs. This comprehensive support for communication protocols ensures that the Beetle ESP32-C6 can be integrated into a wide array of IoT applications, especially within the smart home ecosystem where interoperability and versatility are key.
Beetle ESP32-C6 supports BLE, Zigbee, Wi-Fi 6 and Thread
Figure: Beetle ESP32-C6 supports BLE, Zigbee, Wi-Fi 6 and Thread
Support Wi-Fi 6 to realize ultra-low power consumption IoT devices
With Wi-Fi 6 support, the Beetle ESP32-C6 enables the realization of ultra-low-power IoT devices. As the first Espressif chip to support the Wi-Fi 6 (802.11ax) protocol, it offers improved network capacity, allowing devices to operate efficiently with low latency. Moreover, Wi-Fi 6's Target Wake Time (TWT) technology effectively reduces device power consumption, extending battery life and ensuring long-lasting device performance.
Figure: Wi-Fi 6's Target Wake Time (TWT) technology
  • Ultra-compact size, measuring only 25*20.5mm.
  • Equipped with the ESP32-C6 chip, it supports communication protocols including Wi-Fi, BLE, Zigbee, and Thread.
  • Supports Wi-Fi 6 protocol for lower latency and lower power consumption.
  • Ultra-Low Power Consumption
            Version 1.0: Deep-sleep current of 14µA
            Version 1.1: Deep-sleep current of 37µA
  • Integrated lithium battery charging functionality.
  • Supports battery voltage detection, providing insights into device power levels.
  • Electronic Badge
  • Backpack Charm
  • Pet Tracker
  • Electronic Watch
  • Smart Button
  • Smart Lighting
  • Human-Interactive Device
  • Beetle ESP32-C6 can be used to create wearable devices
    Basic Parameters
  • Operating Voltage: 3.3V
  • Type-C Input Voltage: 5V DC
  • VIN Input Voltage: 5V DC
  • Max Charging Current: 0.5A
  • Sleep Current: (Deep Sleep Mode, Battery-Powered)
            Version 1.0: 14 μA
            Version 1.1: 37 μA
  • Operating Temperature: -10~60℃
  • Dimension: 25x20.5mm/0.98x0.81”
  • Hardware Information
  • Processor: RISC-V single-core processor
  • Main Frequency: 160 MHz
  • SRAM: 512KB
  • ROM: 320KB
  • Flash: 4MB
  • RTC SRAM: 16KB
  • USB: USB 2.0 CDC
  • WIFI
  • WIFI Protocol: IEEE 802.11b/g/n
            IEEE 802.11ax (20 MHz-only non-AP mode)
  • Bandwidth: Support 20 MHz and 40 MHz at 2.4 GHz band
  • WIFI Mode: Station, SoftAP, SoftAP+Station combined mode
  • WIFI Frequency: 2.4GHz
  • Frame Aggregation: TX/RX A-MPDU, TX/RX A-MSDU
  • Bluetooth
  • Bluetooth Protocol: Bluetooth 5, Bluetooth mesh
  • Bluetooth Frequency: 125 Kbps, 500 Kbps, 1 Mbps, 2 Mbps
  • IEEE 802.15.4
  • Compatible with IEEE 802.15.4-2015 protocol
  • Frequency band: 2.4GHz
  • Data rate: 250Kbps
  • Supports Thread 1.3 and Zigbee 3.0
  • Ports
  • Digital I/O x13
  • LED PWM 6 Channel
  • SPI x1
  • UART x3 (LP UART x1)
  • I2C x2 (LP I2C x1)
  • I2S x1
  • IR Transceiver: transmit channel x5, receive channel x5
  • 1 × 12-bit SAR ADC, 7 Channel
  • DMA Controller: transmit channel x3, receive channel x3
  • Beetle ESP32 C6 Mini Development Board x1
  • 10pin-2.54mm Pin Header x2
    Getting Started with Zigbee on Beetle ESP32-C6 Mini
    Projects Getting Started with Zigbee on Beetle ESP32-C6 Mini
    Nickson Kiprotich
    Apr 23, 2025
    DIY Camera Slider Using ESP32 C6 Mini
    Projects DIY Camera Slider Using ESP32 C6 Mini
    Mukesh Sankhla
    Nov 27, 2024
    Heart and respiration monitor with C1001 mmWave Sensor and Unihiker Carrier Board
    Projects Heart and respiration monitor with C1001 mmWave Sensor and Unihiker Carrier Board
    RoniBandini
    Nov 08, 2024
    Wireless UV Intensity Monitor with Beetle ESP32 C6
    Projects Wireless UV Intensity Monitor with Beetle ESP32 C6
    pradeeplogu0
    Nov 08, 2024
    Build Your Own Retro 2-Player Game!
    Tutorial Build Your Own Retro 2-Player Game!
    The Wrench
    Oct 22, 2024
    Smoke and methane detection with FireBeetle 2 ESP32-C6 and Alvik robot
    Projects Smoke and methane detection with FireBeetle 2 ESP32-C6 and Alvik robot
    RoniBandini
    Aug 05, 2024
    Steffen.Lorenz Mar 29, 2024
    I was able to flash MicroPython v.1.22.0 on it! After few experiments with this tiny device, I started to put my "old" NodeMCU into the corner.
