The Aluminum Case designed for the LattePanda Sigma single board server, is made from all-metal material for superior durability. Its wall-mounted design and easy access to all ports and slots ensure functionality and flexibility. A perfect choice for safeguarding LattePanda Sigma SBC.
All-Metal Material for Superior Protection and Stability
The case is made of durable aluminum alloy material, and its all-metal construction gives it the advantage of being sturdy and resistant to impact.
The surface of the case undergoes processes such as bright black anodizing and sandblasting, making it even more scratch-resistant, wear-resistant, and adding a sense of stability.
Wall-Mounted Design for Convenient Placement and Stability
The wing-shaped fixing piece design allows the case to be placed smoothly on a desk or fixed to a wall.
Expandability and Versatility
The LattePanda Sigma aluminum alloy case not only provides comprehensive protection and stability but also offers users more expandability. The case has multiple reserved openings on it, allowing users to expand and connect other devices according to their needs, achieving more functions and expandability.
Note: The case only compatible with the LattePanda Sigma.
Installation Diagram of LattePanda Sigma SBC and Case
Jan 04, 2025
Very good case, optimal for cooling and wall mount.
