This is a metal aluminum heat dissipation kit designed specifically for Raspberry Pi 5. The case is made of aluminum alloy, providing lightweight construction and high strength. The kit includes an aluminum case, equipped with a heat-dissipating copper sheet, an adjustable-speed fan, and an acrylic cover with heat-dissipating holes.
With this case, not only can it protect the motherboard, but the adjustable-speed fan can also automatically adjust its speed based on the temperature of the Raspberry Pi 5, ensuring efficient heat dissipation and maintaining stability and reliability during high-performance operations.
Dimension of Aluminum Case for Raspberry Pi 5 Single Board Computer
Installation Steps of Aluminum Case and Raspberry Pi 5 Single Board Computer
