Gravity: N20 Micro Metal Gear Motor with Integrated Drive (3V-6V, 1:150/133RPM)
$7.90 $12.00
SKU: DFR1114
Notice: Buy 1 items and get 66% off
The miniature metal motor offers simplified control with a PWM servo method, operating at 3V-6V. It's compact, reliable, and ideal for robots and locks.
The Gravity: N20 miniature metal motor series, with its integrated drive chip and PWM servo control method, simplifies motor control. Operating within a voltage range of 3V-6V, it offers a variety of gear ratios and output speeds, catering to diverse application scenarios. The all-metal build, compact size, and reliable quality make it ideal for robots, mechanical motion control, valve control, and door lock control.
The single PWM port controls speed and direction, eliminating wiring troubles and simplifying programming. Performance is optimized with reduced standby power consumption and minimal current consumption when no control signal is present.
The motor operates at a speed of 20,000 RPM unreduced, with a gearbox reduction ratio of 150:1 and a no-load output speed of 133 RPM. It features a PPM signal resolution of 1μs and a PWM drive frequency of 500 Hz. Weighing only 10g and measuring L40mm × W12mm × H20mm, it's a compact and efficient solution for various applications.
Other Models: N20 Miniature Metal Motor Series: A Comprehensive Selection Guide
Connection Diagram of Integrated Drive N20 Motor and Arduino UNO R3
Dimension Diagram of Integrated Drive N20 Motor
  • All-metal N20 motor, compact in size, and reliable in quality.
  • Integrated 360-degree servo motor drive mode for ease of use.
  • PH2.0-3P interface, Gravity line sequence standard, convenient for connection and insertion.
  • Robot
  • Mechanical motion control
  • Valve control
  • Door lock control
    Power Parameters
  • Operating Voltage Range: 3V-6V
  • Rated Voltage: 6V
  • No-load Current: 50mA (under 6V)
  • Static Current: <1mA (no PWM control signal input)
  • Stall Current: 640mA
  • Motor Parameters
  • Motor Speed (Unreduced): 20,000 RPM
  • Gearbox Reduction Ratio: 150:1
  • No-load Output Speed: 133 RPM
  • Stall Torque: 1.0 kg*cm
  • Control Parameters
  • PPM Signal Resolution: 1μs
  • PPM Signal Positive Pulse Width Range: 500μs-2500μs
  • Forward Pulse Width Range: 500μs-1400μs (maximum speed at 500μs)
  • Stop Pulse Width Range: 1400μs-1600μs
  • Reverse Pulse Width Range: 1600μs-2500μs (maximum speed at 2500μs)
  • PWM Drive Frequency: 500 Hz
  • Other Parameters
  • Weight: 10g
  • Dimensions: L40mm × W12mm × H20mm
  • Motor with Integrated Drive - Speed 133RPM (1:150) x1
  • Gravity 3-Pin Digital Sensor Cable x1
    Blog N20 Miniature Metal Motor Series: A Comprehensive Selection Guide
    Mar 11, 2024
