RS485 4-in-1 Soil Moisture, Temperature, pH & EC Sensor for Smart Agriculture (IP68, 5-30V)
$69.00
SKU: SEN0604
  • $68.00 3+ items
  • $67.00 5+ items
  • $65.00 10+ items
The 4-in-1 soil sensor measures temperature, humidity, electrical conductivity, and pH. It uses RS485 and MODBUS-RTU for accurate, stable readings, suited for diverse agricultural applications.
The 4-in-1 soil sensor is designed to monitor key soil parameters: temperature, humidity, electrical conductivity (EC), and pH. With its wide voltage power supply range of 5-30V and RS485 data transmission using the reliable MODBUS-RTU protocol, this sensor delivers rapid, accurate, and stable readings, enabling optimal irrigation scheduling and precise soil management. It is compatible with the Arduino UNO and TTL to RS485 expansion board for easy setup. It is suitable for a variety of agricultural, horticultural, and environmental applications, including greenhouse farming, large-scale irrigation systems, and scientific research. For most soil monitoring projects, this 4-in-1 sensor provides all the necessary data in one device, eliminating the need for multiple individual sensors.
The soil sensor features an automatic temperature compensation function for conductivity, ensuring measurement accuracy regardless of environmental changes. Its applications span across agricultural irrigation, greenhouses, floriculture and vegetable farming, grassland pastures, rapid soil testing, plant cultivation, scientific experiments, grain storage, and the measurement of moisture content and temperature of various particulate matter.
Soil temperature and moisture directly influence plant growth and nutrient absorption. Soil electrical conductivity (EC) represents soil salinity, a crucial indicator of soil fertility and health. High soil salt content hinders water absorption by plants. Soil pH, or “soil reaction”, is an acid-base reaction of the soil solution, dependent on the concentration of hydrogen ions. It’s expressed by the pH value, with 7 being neutral, less than 7 acidic, and greater than 7 alkaline. Soil pH can generally be divided into the following levels:
<4.5 Extremely acidic
4.5-5.5 Strongly acidic
5.5-6.5 acidic
6.5-7.5 Neutral
7.5-8.5 alkaline
8.5-9.5 Strongly alkaline
>9.5 Extremely alkaline
  • With automatic temperature compensation, high precision, fast response and stable output
    Applications of RS485 Soil Sensor - Scientific Experiments. Grain Storage
  • Power consumption: 0.5W@24V
  • Output mode: RS485
  • Detection parameters: Temperature,、Humidity、Electrical Conductivity (EC)、PH
  • Humidity parameters
             Measuring range: 0-100%
             Resolution: 0.1%
  • Temperature parameters
             Measuring range: -40°C~+80°C
             Resolution: 0.1°C
             Accuracy: ±0.5°C
  • EC parameters
             Measuring range: 0-20000us/cm
             Resolution: 1us/cm
             Accuracy: 0-10000us/cm@±3%FS, 10000-20000us/cm@±5%FS
             Temperature compensation: memory temperature compensation, compensation range 0-50°C
  • pH parameters
             Measuring range: 3-9pH
             Resolution: 0.1pH
  • Protection level: IP68
  • Working temperature: -20°C~+60°C
  • Cable length: 2m
  • Size: 123*45*15mm
  • RS485 Soil Sensor(Temperature & Humidity & EC & pH) x1
    Jan 13, 2025
    $39.50
