Home Assistant Green is a powerful and privacy-centric smart home hub designed to automate and control all your smart devices from a single platform. Compatible with Apple HomeKit, Google Home, Samsung SmartThings, and Amazon Alexa, this device integrates seamlessly into existing smart home ecosystems. With a robust 1.8 GHz Quad-core ARM processor, 4 GB RAM, and 32 GB eMMC storage, it offers high performance and future-proof scalability.
Figure: The perfect hardware for Home Assistant
Easy Setup and Use
Home Assistant Green is ready to use out of the box. Simply plug in the power and network cables, and the intuitive mobile apps will guide you through the setup process, allowing you to enjoy home automation without complexity.
Figure: Plug and Play
Seamless Smart Home Integration
Home Assistant Green supports a wide range of smart devices across different ecosystems, including Apple, Google, Samsung, and Amazon. It brings them all into one app, allowing easy control and automation of hundreds of thousands of devices.
Figure: Works with (almost) Everything
Data Privacy and Local Storage
By default, all data is stored locally, ensuring that users retain full control over their data and enhancing privacy. There is no need to rely on cloud services, making this device the ideal choice for security-conscious users.
Memory:
Networking:
Wireless Connectivity:
Indicator LEDs:
Power Control:
