RS485 Photoelectric Solar Radiation Sensor (400-1100nm)
$59.00
SKU: SEN0640
  • $57.00 3+ items
  • $56.00 5+ items
  • $54.00 10+ items
The RS485 Photoelectric Solar Radiation Sensor is designed to measure solar radiation in the spectral range of 400-1100nm. It uses the photoelectric principle to convert sunlight into electrical signals. Featuring a highly sensitive photosensitive element and a wide-spectrum absorption range, the sensor delivers accurate solar radiation measurements.
The integrated dust cover, with a transmittance of up to 95%, ensures minimal interference from environmental factors, further enhancing measurement accuracy. Additionally, the sensor operates with a wide voltage range of DC 5-30V and supports Modbus-RTU communication via RS485, making it an ideal choice for integration with Arduino.
Wide Voltage Support
The sensor operates on a DC 5-30V power supply, ensuring compatibility with various systems and making it versatile for different applications.
High Sensitivity and Wide Spectrum Range
Utilizing high-precision photosensitive elements, the sensor ensures accurate measurement across a broad spectrum, from 400 to 1100nm, making it ideal for solar radiation applications in various fields.
Durable and Environmentally Resistant
The sensor is housed in a rugged metal aluminum shell with an IP67 protection level, ensuring durability and reliability even in harsh outdoor environments. The dust cover is specially treated to reduce dust absorption, enhancing long-term stability and performance.
The RS485 Photoelectric Solar Radiation Sensor Integrated Dust Cover
  • Crop Growth Monitoring: Measure solar radiation to optimize agricultural practices.
  • Photovoltaic Systems: Monitor solar energy input for efficient power generation.
  • Meteorological Monitoring: Collect solar radiation data for weather analysis.
  • Plant Physiology Research: Study the impact of sunlight on plant growth.
  • Environmental Protection: Assess solar radiation for ecological research and conservation efforts.
  • Power Supply: DC 5-30V
  • Working Current: <10mA
  • Output Mode: RS485
  • Measurement Range: 0-1800W/m²
  • Wavelength Range: 400-1100nm
  • Accuracy: ±5%
  • Resolution: 1W/m²
  • Response Time: ≤10S
  • Non-Linearity: <±2%
  • Annual Stability: ≤±2%
  • Cosine Response: ≤±10%
  • Operating Temperature: -25°C to +60°C
  • Protection Level: IP67
  • Sensor Cable Length: 20cm
  • Adapter Cable Length: 70cm
  • RS485 Photoelectric Solar Radiation Sensor x1
  • Adapter Cable x1
  • Screw Package x1
  • RS485 Photoelectric Solar Radiation Sensor (400-1100nm)
    $12.90
