The FireBeetle 2 ESP32-P4 is a high-performance microcontroller (MCU) development board designed based on the ESP32-P4R32 chip. It supports single-precision FPU and AI instruction extensions, and has powerful AI processing capabilities. At the same time, the development board also has powerful image processing capabilities, supporting up to 1080p@30fps image acquisition and display. The development board integrates the ESP32-C6 module, which expands the WiFi and Bluetooth functions and is suitable for various applications such as AI network cameras, AI robots, smart home central control screens, and digital photo albums.
Excellent Performance, Powerful Edge AI Processing Capabilities
The FireBeetle 2 ESP32-P4 development board is equipped with a 32-bit RISC-V dual-core 400MHz high-performance processor. Combined with 768KB of L2MEM and 32MB of PSRAM, it provides strong power for complex computing tasks. The ESP32-P4 supports single-precision FPU and AI instruction extensions and can run lightweight machine learning models (such as TensorFlow Lite) to achieve AI functions such as edge voice recognition and image classification. It is suitable for applications such as voice interaction, AI face recognition, AI cat's eyes, and AI surveillance cameras.
High-speed Peripherals, Smooth Human-Machine Interaction
The FireBeetle 2 ESP32-P4 microcontroller integrates a JPEG encoder/decoder, a Pixel Processing Accelerator (PPA), an Image Signal Processor (ISP), and an H264 video encoder. It can efficiently handle tasks such as images and video streams, support MIPI-CSI and MIPI-DSI signal inputs, and support up to 720p@88fps or 1080p@30fps image acquisition and display at the highest level. It brings a smooth visual experience of human-machine interaction to applications and is suitable for applications such as digital photo albums, home central control screens, and multimedia advertising displays.
Richly Integrated Peripherals, Simple and Easy to Use
The FireBeetle 2 ESP32-P4 development board integrates rich and easy-to-use peripheral interfaces in a size of only 25.4x60mm, reducing the difficulty of connecting external devices. The development board integrates the ESP32-C6 module, which expands the WiFi and Bluetooth functions, enabling the ESP32-P4 to connect to the Internet and expand more usage scenarios. The onboard Type-C USB OTG 2.0 high-speed interface can achieve high-speed communication between the development board and USB devices; the onboard MIC can collect sounds to achieve voice recognition; the onboard TF card slot provides a large-capacity data storage solution for projects.
Basic Parameters
Hardware Information
CPU and Storage
WIFI
Bluetooth
Interface Pins
Note: The functional pins are multiplexed, and the above number of interfaces is the maximum value.
Board Overview
