DFRobot Beginner Kit for Arduino (Best Starter Kit)
$34.90
SKU: DFR0100
Purchase this product and earn 349 reward points, which are tied to VIP membership program. Learn More >
Welcome to the interactive electronic world!
DFRobot proudly presents the Beginner/Starter Kit for those who are interested in learning about Arduino and electronics. Starting from basic LED control to more advanced environmental sensing, monitoring, and actuators, this kit will guide you through how to sense and control the physical world through sensors and microcontrollers compatible with Arduino via carefully designed project. Besides providing you with premium quality jumper wires, double resistors, plenty of LEDs, 9g servos, and IR remote transmitters and receivers, the 4 additional useful components have also been added: relay, motor, fan, and potentiometer.
HIGH-QUALITY ELECTRONIC COMPONENTS ENTRY-LEVEL EDUCATION
A DFRduino UNO R3 (Compatible with Arduino Uno R3) is compatible with  Arduino IDE. Both the DFRduino and DFRobot's best selling prototype shield based on Arduino included in this kit.
Beginner Kit for Arduino has strict guidelines on how it makes packaging design, hardware selection, and circuit production technology, meaning that DFRobot can always provide you with quality assurance.
SYSTEMATIC COURSE SETUP
(1) Course Outline
There are 15 projects in the Arduino Getting Started tutorial to help you learn Adruino step by step from easy material to even the most difficult of concepts. The whole set of tutorials provides learning content for both the software and hardware systems. In the process of making interesting projects, you will not only learn programming knowledge such as variables and functions, but also understand the principles behind using electronic components such as light-emitting diodes, buzzers, and steering gears.
Tutorial PDF of 15 Arduino IDE compatible projects by DFRobot
(2) Course Structure
Each course will guide you through a quick implementation of the project, stimulate your interest in learning, and then delve into the knowledge of electronics and programming. So, the structure of this curriculum is broken down into the following: “materials list --> hardware connection --> code writing --> code review --> hardware review.”
Different from other tutorials, this tutorial systematically explains how to interpret Arduino code and how to understand the principles of electronic circuits in order to help you make creative Arduino programming projects.
(3) Project Cards
The beginner kit for Arduino includes 15 project cards with detailed circuit diagrams. The students can choose any project they want to start creating what they are interested in. The kit effectively helps teachers launch workshops at school.
DFRobot 15 Project Cards with detailed circuit wiring diagrams
USER-SPONSORED CONTENTS
(1) User-sponsored mobile app for developers. Programming Anywhere!
Beginner Kit for Arduino - Mobile App
(2) User-sponsored translations into English, Korean, Russian, and other language tutorials.
Other Language Tutorials for Beginner Kit
UNBOXING VIDEO
Learn Arduino Easily by Using Simple Project Kit
DFRobot Beginner Kit for Arduino® [What's Inside? + ANNOUNCEMENT]
  • DFRduino UNO R3  x1
  • Prototyping Shield  x1
  • Jumper Cables M/M x30
  • Jumper Cables F/M x10
  • Resistor 220R x20
  • Resistor 4.7K x20
  • Resistor 10K x20
  • Resistor 1K x20
  • 5mm LED x10
  • IR Receiver Diode x1
  • Mini Push Button x4
  • Ambient Light Sensor x1
  • Tilt Switch Sensor x1
  • 8-Segment LED x1
  • LM35 Temperature Sensor x1
  • Relay x1
  • Buzzer x1
  • Fan x1
  • 130 Motor x1
  • 10K Potentiometer x3
  • Micro Servo x1
  • Mini Controller (with battery CR2025 inside) x1
  • 6 x AA Battery Holder x1
  • 400 Tie Point Interlocking Solderless Breadboard  x1
Beginner Kit for Arduino Tutorial
Course Beginner Kit for Arduino Tutorial
Nov 26, 2024
Basics of Arduino (TINKERCAD)
Projects Basics of Arduino (TINKERCAD)
Mukesh Sankhla
Mar 09, 2023
Beginner Kit for Arduino Mobile Application is now available on Google Play!
Blog Beginner Kit for Arduino Mobile Application is now available on Google Play!
Nov 29, 2017
Elvis.Elvis Jan 27, 2025
I have enjoyed working through this kit. I received this unit in a reasonable amount of time. The kit is well put together, You will notice in my pictures that inside the box top there is a list of all components. Also notice how everything in a bag and easy to identify. Also in the box top you will notice they have listed links to the tutorial PDF and to several other helpful places. The book that you receive has a page that tells you exactly what and how many you need of each item. Very nice. Then on the opposite page you see a picture of how to wire everything up for that project. Notice i took a picture of the actual board and shield that you receive. I have had no issues at all with this board. It works great. and has a few nice features. I think it is well worth the price.
Tim. Jan 24, 2021
In my opinion, this is the best Arduino starter kit for the money. This kit includes everything you need to get started learning Arduino, the documentation is clear, and the progression of each lesson builds on the previous one. The components are better than most kits out there and a good indicator of this is the inclusion of items like 5-band resistors and robust jumper wires. I liked this kit so much I purchased another one for a family member this past Christmas.
Mattia. Aug 07, 2023
All ok, the description write in a good way.
$34.90
