Light Disc with 7 SMD RGB LED
$3.90
SKU: DFR0106
  • $3.75 3+ items
  • $3.70 5+ items
  • $3.60 10+ items
This fantastic light disc consists of 7 SMD RGB LED.  It illustrates a beautiful color combination much better than traditional RGB led.  You can control the LEDs via the RGB pins. By pulse-width-modulating the pins any color can be created by mixing different amounts of red, green, and blue. Running from a 5V source, these LEDs are painfully bright. With a proper case, a beautiful mood light is just up and running.
Ideal for Arduino lighting project.   It can be powered by Arduino Digital Pin out with only USB power supply.
It has buildin resistor, it will work flawlessly with Arudino  5V power.
The image above is using this light disc with a glass cover, with proper sensor, you can make your own mood light or music light
  • Power Supply: 5V
  • 7 SMD RGB LED
  • 6000 mcd
  • Light Disc with 7 SMD RGB LED    x1
