Micro Metal Gearmotor 50:1
$5.90
SKU: FIT0094
Micro metal gearmotor with D-shaped shaft, compatible with specific wheels. Features 50:1 gear ratio, 13000rpm (no gearbox), 400rpm with gearbox.
This motor has a long (0.365" or 9.27 mm), D-shaped metal output shaft that matches the Pololu wheel 42x19mm and 32x7mm. The brass faceplate has two mounting holes threaded for M1.6 screws (1.6 mm diameter, 0.35 mm thread pitch), or you can use the mounting bracket or extended mounting bracket, which are specifically designed to securely mount the gearmotor while enclosing the exposed gears. We recommend the extended mounting bracket for wheels with recessed hubs, such as the wheel 42×19 mm.
  • Motor speed (No gearbox):13000 rpm
  • Gear ratio: 50:1
  • Motor speed (with gearbox): 400rpm±10%
  • Rated current: 55mA @ 6V
  • Stall current: 350mA @ 6V
  • Stall torque: 0.39kg*cm @ 6V
  • Micro Metal Gearmotor    x1
Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
Projects Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
RiverTrue
Nov 08, 2024
